Question about Ovens
Will my kenmore gas self cleaning oven automaticaly turn off when its done with the cleaning or will I have to turn it off after so long.
  • joyce_lance Jun 06, 2010
    Yes the solution was helpful, The door unlocked after 3 hours and 45 minutes but the light never went off I had to turn the knob to the off position. Thank you
  • 2,841 Answers
It will heat up to a predetermined temperature of around 1,000 degrees, and lock the door. After it completes the cleaning cycle, about 2 hours, the door will stay locked until it cools down about 2 hours on average. So you will have a total cycle time of around 5 hours. All done automatically unless you want to control the time yourself and it is equipped for that option. Some models do allow you to control the time of the cleaning. If you have lost your owner's manual you can get one here for free. http://www.managemylife.com/
Posted on Jun 06, 2010
    Will the clean light go off or do I need to turn the knob off after 2 or 3 hours? It's been cleaning for over 3 hours now and the light is still on and the door is still locked.
  • NOT ME Jun 06, 2010
    If it has been cleaning for over 3 hours wait another 30 minutes and if it does not shut down, turn if off manually. Remember even after the cleaning cycle is over you cannot open the door until it cools down which could take up to 2 hours.
How do i run the self clean cycle?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Mar 14, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
We are renting our townhouse. It came with a gas Kenmore oven. Someone (maybe even me) has done something to trigger the "LOC" display on the oven, meaning the door is locked, presumably for...
Hi
First press the CANCEL/Delay button for 20 seconds...If this won't work then you can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if the not then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 26, 2011 | Kenmore Ovens
When i try to bake in my kenmore gas oven it gos to self cleaning mode and will not let me use the oven
Some how somebody pressed self clean and didn't let it finish. Press self clean again, let it run thru' and then U wil B A O K.
Aug 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 | Ovens
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
How do I know when my self cleaning oven is over for Roper gas ra
If you have a digital display it will tell you when it's done,If not the average is about three hours for cleaning and another hour + for cool down the door usually won't open till the temp inside gets below 300 F but you can cancel the cycle anytime you like.
Sep 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Self cleaning
Never use spray cleaners in a self clean oven it will void your warranty and possibly ruin the oven. it sounds like what may have happened is the fumes from the spray ignited inside the oven and may have blown out the pilot light if your using gas.
or maybe replace the thermocouple. sorry, hope that helps.
Aug 03, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
