Question about Craftsman Garden
I have a Craftsman 4.6 amp , etc.
I have a Craftsman 4.6 amp "Hasslefree" (what a laugh!) Head and refills to go with it. Trouble is, after about three feet in operation, the refill cord breaks and has to be replaced. Some of it fuses and is hard to remove.
I also have a Frigidaire Home Products Weedeater Twist'n Edge with a reel. Here too, after about three feet the cord breaks and has to be pulled out. Sometimes it won't move. On this device you're supposed to press down to release more cord, but pressing down does nothing, the cord doesn't move.
Any solution to either or both?
erickg
  • 116 Answers
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Posted on Apr 17, 2009
  • 57 Answers
SOURCE: how to install the Speed Spool Bump Knob Assembly
Do you have an owners manual? If not, try poulan.com
Posted on May 19, 2009
darth yoda
  • 4 Answers
SOURCE: Wont start
try and change the solenoid!!
Posted on May 29, 2009
  • 27 Answers
SOURCE: broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
Posted on May 31, 2009
rycgl
  • 1545 Answers
SOURCE: Have a Twist N' Edge Weedeater. Can't find the
You may find a manual with that info in it here:
http://www.manualsonline.com/
Posted on Aug 14, 2010
How can I make the spool for my craftsman electric weed trimmer stay on?
go purchase a new head assy or have someone show you what you're doing wrong or both
or better yet, visit Sears and seek their help
Mar 11, 2015 | Craftsman 12" 4 Amp Electric Weed Trimmer...
How do you replace the trimmer head on the Craftsman 27cc trimmer (Model 711170)?
U-tube has some good videos on all sorts of replacements on heads , lines...etc.
May 13, 2014 | Craftsman Convertible 25cc. Gas Line...
Thread continues to tangle on Ellure Plus even after changing out needle, bobbin, etc. Noticed that a small 'bar' was across front of feed dogs-pushed this back to the left but problem contin
Your post made me laugh with the funny bone remark. :) I'm glad you found and posted a solution to your own problem. Bravo!
Happy sewing.
Sep 15, 2012 | Baby Lock Ellure
I'm trying to get my Canon iP4200 to print in BLACK ONLY
Hi . I think the print head may be is clogged. If cleaning didn't correct the problem . Print head need to be replaced
Jun 25, 2017 | Canon PIXMA iP4200 InkJet Photo Printer
I want to year laugh
1 - pick up the phone 2 - ask the assistance of some friends or co workers (2 at least) 3 - smash the phone on the shorter one's head (easier to reach) 4 - collect laughs!
Mar 16, 2011 | Innovage Touch-panel Phone 1502084
My compressor hose is running extremely hot...any reason why and do i have anything to worry about
Assuming that it's used in an open-air spot so that the intake air is cool, hot compressed air means the head is running hot.
Most small-to-mid sized compressors run warm after a few minutes, and some run fairly hot after 10 minutes.
If the hose is too hot to hold after 20 minutes, the first suspect is friction within the compressor's head.
This could be caused by poor circulation due to a low-quality oil.
It could also mean a blockage in the air-delivery system (ie: oil-dust gunk at a fitting causing restriction, making the motor work harder than normal.
Flush the oil reservoir, pull the feed lines one-at-a-time and flush out. Pull the intake filter and blow out the head & valves.
Refill the reservoir with Craftsman compressor oil.
Sep 08, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
1995 Oldsmobile over heats How do I fix it?
CHECK H2O PUMP AND SEE IF IT IS NOISY
CHECK TOP & BOTTOM RADIATOR HOSES
OPEN RADIATOR & CK FLUID LEVEL ANTIFREEZE - GREEN NOW BROWN
ANY DOUBTS - FLUSH THE RADIATOR REFILL ANTIFREEZE..
NOW IF ALL THAT LOOKS GOOD..
YOU MAY HAVE A STUCK THERMOSTAT
OR AT WORST CLOGGED RADIATOR..
NOW THE WORST.. YOU MAY HAVE A CRACKED HEAD SO PULL OUT THE OIL DIP STICK AND SEE IF YOU HAVE H2O IN THE OIL...
IF SO... YOU ARE IN BIGGER TROUBLE HOWEVER YOU MAY SIMPLY A HAVE A BLOWN HEAD GASKET.. OK THATS WHAT YOU NEED TO DO FOR A .
START. GOOD LUCK!
Aug 15, 2009 | 1995 Oldsmobile Cutlass Supreme
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
I refilled the blackcartlage but its not printing anything anymore
You probably have an air bubble. Take out cartridge and clean the head and points with proper solution. Place tissue under the ink output area, and gently blow area where you refill. This will clear block. Gently push an unscented wet wipe under ink output, and make sure colour is uniform and coming out easily, reinstall it. Your mistype of cartridge as cartledge made me laugh, as we do get so angry with printers they nearly become human to us, and we wish they did have cartledge as we could shoot them!!! lilac gerry ps don't forget to reset ink levels for new cartridge xxx
Jan 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Garden Logo
73 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
