Question about Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
Toilet not refilling water
If I hold down the handle, the water empties and refills without problem. If I just push the handle, the water SOMETIMES empties, but will hardly refill. I replaced the flapper and the chain. The chain has some slack, as requested by the Kohler brand.
  • 349 Answers
A couple of thing's to check the fill tube in the tank is it connected from the fill valve to over flow. This fill's th ebowl up with the required amount of water.
Next is the water filling to the line on the fill tube with in 5/8 " from top of tube. Adjust the float to get it with in the fill amount required.
The chain on the flapper need's some slack, you just have to move it a little till it get's adjusted right. Water level low in the tank will affect the flapper also.
I hope this will be of some help for you.
Posted on Jun 07, 2010
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
Why is the cistern noisy when refilling
remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
May 09, 2014 | Caroma toilet - water saving Sydney Low...
When flushing, only a small amount of water leaves the tank, and the bowl just empties. The chain has a little slack to close, however, it does not hesitate at all. When flushing, the chain lifts the...
Try holding the handle down until the tank empties completely. If the tank leaks into the bowl during or after refill, the flapper is defective and not sealing correctly.
Jun 21, 2017 | Kohler Memoirs toilet tank with Stately...
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | American Standard Home
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
362 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
