Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
No Suction in hose
I can use it to vacuum but when I try to use the hose the suction is bad and it sounds like the suction is at the top of the part that you take off to empty and it gets loud, you can feel the suction from the vent at the top of that part as well.
  • 736 Answers
You have a clog in the hose ... you can use a mop handle or other long (not sharp) stick or wire to poke down the hose and push out what ever is in there .. be careful not to poke holes in the hose .. sometimes if you just hold the hose backwards to the where the suction is (where its normall connected but this time switch ends) .. then it frees the clog ..
Posted on Jun 07, 2010
Loss of suction in hose
your hose is blocked get some thing long and thin push it done the hose and try and clear it
Dec 17, 2013 | Dyson DC40 Multi floor Upright Vacuum...
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
c...
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
A Dyson dc 17 Animal and the wand/hose has lost suction
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Not picking stuff up and no suction in hose as well, suction sounds good until you go to vaccuum floor
Because this unit is bagless there are more gaskets to seal the suction portion of the vac. you are most likely missing a seal, can you remove the basket and place your hand near the suction on the vacuum? it is shielded so you wont lose fingers. if there is suction there, look at the bottom of the basket for a gasket, same for the top
Jan 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Low suction
Is the suction low at the tank after you disconnect the hose? If it is strong there, then the hose may be clogged. You can unhook the hose from the wands to see if you have suction or not. If you do, then look further down all the way to the brush roll. The other possible is if no clogs, check the filters, on the E series, there is a filter on the back, there is some also had one in the top and you would have to take it apart to get to it. One other is that the motor is not running at top speed and may have to be replaced. It can sound ok, but will have reduced suction. If you suspect the motor, check your owner manual, some of these newer ones had a long warr. period on the motor.
Feb 13, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
183 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
