Question about Maytag PYE2300AY Electric Dryer
MDE3000AYW DRYER RUNS BUT NO HEAT - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerMDE3000AYW DRYER RUNS BUT NO HEAT - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check ouMDE3000AYW DRYER RUNS BUT NO HEAT - 2_bing.gif that I wrote about this problem...
Dryer2_bing.gif TrouMDE3000AYW DRYER RUNS BUT NO HEAT - 2_bing.gifg2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 06, 2010
Maytag neptune dryer model mde3000ayw wont start
If it only runs with start button held in then you have a problem with the door switch. Check to be sure the wires are on it. Here is the switch to order in case it is bad.
Nov 29, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Squeeky noise in the back of dryer when running?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag MDE9316 Dryer
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
Cold blooded neptune
check the hi-limit switch on the element case and the cycling switch also there for continuity,then check the thermal fuse for continuity its in the exhaust vent area
Mar 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer turns on and runs gets hot an turns off smells hot and burnt. model #mde3000ayw
It sounds as if the blower motor / fan is not working, or the ducting is blocked.
This needs to be checked ASAP as it can cause a fire risk in older models.
Sep 29, 2009 | Dryers
Belt is broken on my Magtag Neptune Dryer #MDE3000AYW. How do I take the front panel off to get to the belt?
Hello del4221,
Here is a link to your dryers assembly drawings and parts lists. http://www.pcappliancerepair.com/model-display.php
You should be able to see how it is assembled and be able to disassemble it with this documentation.
Hope this helps..
Regards
Rick
Jan 07, 2009 | Maytag MDE9700AYM Electric Dryer
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
144 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
