Question about Hayward Navigator Pool Cleaner
Why are the paddles not working on pool cleaner?
  • 640 Answers
Your shoes or wings might be worn/broken. If this is the case, they will need to be replaced. Also, you might have improper tension in the rear flap. There is a built in rear flap adjuster on these automatic pool cleaners that you should be able to turn. That will give you the proper tension on the rear flap.
Posted on Jul 20, 2010
Polaris 280 moves around but does not pick up debris
check inside see if hoses came off or paddle wheel jammed
Nov 14, 2012 | Polaris 280 In - Ground Pool Cleaner with...
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
Nitro N71 does not climb the walls of my Acrylic mosaic swimming pool. I fitted the replacement front and rear paddles with the foam wheels but this did not do the trick.
None of the robotic cleaners are going to climb that surface well. Off all the options out there the Aquabot with the foam brushes is likely your best option for an acrylic pool. The Dolphin version can have rings added to their brushes but that may not be enough. You may try to get a rental unit from a local shop or pool store to try out before committing to the purchase so you will know if it work before buying it.
John
Oct 21, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
My ****** sucks but it won't go forward. i had all gears and gear box replaced, shoes, wings, could it be the front flap? when i take off the front flap it moves forward. we borrowed a used loaner from the...
You can try "A" frames and a new paddle wheel. If these are bad the suction can be real good and you can get some movement out of the cleaner but as soon as it get's a load on it, it will stop.
Oct 10, 2010 | Hayward Navigator Pool Cleaner
My hayward navigator just moves in a circle. I picked up the navigator and saw that one of the paddles is not moving. When i pressed down on the paddle that was not moving it starts moving but as soon as I...
It wouldn't hurt to replace the pods (paddles). Also, the wings, flaps, A-frame, turbine, feet(shoes) and the gearbox. All of these things wear and should be done about every 12-18 months, as needed. Before you do any of this, though, try tightening the screw on the pod that's not working. These screws need to be very tight.
www.cpo2go.com
May 20, 2010 | Hayward Navigator Pool Cleaner
Vacum does't move,
If the unit is pulling water and the flippers are moving, try hold ing the flippers and see if you can keep them from moving. This is probally what you will find. It will mean that your "A" frame is worn, or the bearings on the rockers, or the cams on the paddle wheel are worn. All of witch can be looked at at your local pool store and usually they will only charge for the part's used. Good luck and write back if this doesn't fix it and we can go from there
Mar 09, 2010 | Hayward Navigator Pool Cleaner
Aqua critter
Remove the center inlet port and check for some sort of blockage in the intake jamming the drive paddle.
Jun 14, 2009 | Hayward Aquabug Above Ground Pool Cleaner...
Hayward Navigator Pool Cleaner Logo
133 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
