Question about Opti -UPS PowerES 650 UPS System
UPS An OPTI ups 550c indicates fault battery then cuts off power
  • vondougie Apr 11, 2008
    The UPS gave this problem from tests with new batterriesand indicates bad battery
  • vondougie Apr 14, 2008
    can i have a technical manual so that i can use it to track where the sensing fault could be arising from.I tried to download but i am failing
    Brigadier General:
  • 6,966 Answers
All UPS uses some sort of battery to power the unit in the event of a power outage. Like car batteries they also have a life span which can be a couple of months to a year or so. If the UPS has been in service for some time, perhaps it simply needs a replacement battery. On the other hand, if the unit is fairly new and carries warranty, it may be to your advantage to consult your dealer and claim for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 10, 2008
  • Louie  Role
    Louie Role Apr 11, 2008
    Should you at the onset have indicated that this fault exists on either new or old batteries, then a more appropriate initial response could have been given such as a check of the circuitry that senses the battery condition which could either be a simple zener/SCR combo. My solution, that you rated as inappropriate, is only reflective of how the question/problem was posted.
    I wish you luck with your concern.
Opti ups 1000 goes from battery to line and back and forth
check the input relay circuit. the issue might be cause by the welded relay
Aug 26, 2014 | Opti -UPS PowerES 1000 UPS System
Uninterruptible Power Supply Faults
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage of each battery may show 13 volts when tested with a multi-meter. This is a float voltage and a true indication of the battery voltage and its condition requires each battery to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault.
Also a faulty charging circuit will not charge the batteries and will cause a fault condition warning.
on Dec 06, 2009 | Opti - UPS ES800C 800VA 480W 1050 JOULES...
550c manual opti ups KEEPS SHUTTING DOWN
Hi Gerald,
You probably need to replace the battery inside of the UPS. Battery price is $27.30. If you can explain in more detail what is going on then I may be able to help you more.
Feel free to call me if you
Oct 09, 2013 | Opti -UPS PowerES 650 UPS System
Opti-ups ps1500b can't start only gives a long beep
Replace your battery. A 12v 7aH battery will cost you 24USD.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website:
Nov 27, 2012 | Opti (PS-BP3000B) (PS-BP3000B) UPS System
Hi, I have an Opti-UPS ES 1000C. When power goes off, it beeps and shuts down. Everything plugged into it shuts off. It does not convert to battery power. What's wrong?
The Batteries are bad. It can't convert to battery because the batteries are bad. Plug the UPS back in then pull the plug. If if goes off the batteries are bad
Sep 06, 2011 | Opti -UPS PowerES 1000 UPS System
What battery connecting wires go to the POS and NEG battery pack for the Opti 1000B UPS? Black to Red or Black to black terminals. Thanks in advance. Jim
Black wires indicate NEUTRAL...RED or BROWN indicate Live. If you have a multimeter, I would suggest you check the polarity of each. Connecting wrong may cause a spark and possibly blow a fuse.
Feb 09, 2011 | Opti -UPS E-Series 1000 UPS System
My Opti-UPS 650ES needs repair. I bought a
tgliang, I appears that the company Opti-Ups is no longer supporting this UPS. Best bet for you will be to get a new unit to replace it. Check the Opti-Ups website. 12fixlouie
May 20, 2010 | Opti -UPS PowerES 650 UPS System
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Opti-UPS 1400ES UPS unit - Beeping 14 Times, stops, Beeps Again.
you can try this asia systems technologies look for our sale person william +65 65478990 i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
Opti -UPS PowerES 280 UPS driver and manual
Have you tried installing the software for your UPS found on this page?
Usualy installing the software will also install the driver.
Feb 23, 2008 | Opti -UPS PowerES 280 UPS System
Opti -UPS PowerES 650 UPS System Logo
229 people viewed this question
Top Opti Computers & Internet Experts
David Payne
David Payne
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
