Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
Hi where should i get ac adapter for lacie model 300790ur and what is the ac adapter model number thanks
Can you please provide me the power adapter specs? I need to buy a new one.
I found This power supply
It is listed as suitable for the Porsch drives, but the model number on your current unit should tell if it's the right one.
At 12V 3A it is rated higher than the common 12V 2A which is a common rating for hard drive power adapters, and also supplies 5V. These may be required for your drive.
The site has other LaCie power adapters if the model number does not match.
Feb 09, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
When I came back from holidays, the battery on my APS surge protector had died. I got a new surge protector: problem is, now my LaCie extreme d2 isn't seen on my desktop, so I can't back up. The blue light...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | LaCie d2 Extreme 250GB External with...
Hi I have a macbook and the 500 gb lacie hd when I connect the usb to the port, the macbook does not recognize the source. I have used it previously and it has worked and I can't seem to get it working...
* the USB cable
* the power-adapter
Dec 12, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie drive runs when plugged into the computer but the icon no longer appears on desktop and drive is unavailable.
* the USB cable
* the power-adapter
Nov 10, 2010 | LaCie (300770) 250 GB Hard Drive
The lacie grand 1 tb usb hard drive will turn on but it's logo is not appearing on my desk top and I can't access any of my files from it. Any ideas?
* the USB cable
* the power-adapter
Nov 08, 2010 | LaCie Grand 1 TB USB 20 Hard Drive
I have a Lacie 160GB external HD that seems to have power supply issues. When I plug it in an turn it on, the blue light comes on and "shimmers" - it's not a full glow, but it's not a flicker...
The Lacie has four major components:
* the USB cable
* the power-adapter
Nov 07, 2010 | LaCie (300740) 160 GB Hard Drive
I have a G530 and need part number for ac adapter
These are the part numbers 42T4457, 42T4465 . Thanks.
Jun 17, 2010 | Lenovo 3000 G530 Notebook
Strange noises, disk won't fully spin or start up...
Your AC adapter is "dying", and must be replaced.
Is it still under "warranty", i.e., you contact LaCie,
get an RMA (Return Materials Authorization) number,
they ship you a new adapter. If you ship them the old adapter,
within a week, they will _not_ charge your credit-card the $30.
Sep 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I need a power cable for a lacie FA Porsche desktop drive
Hi John,
Replacements are generally harder to acquire than hens teeth. If you cannot find one, the much simpler solution is to take your drive to a PC shop and ask the technicians to put the drive in a new enclosure for you which will come with it's own AC adapter included.
Hope this helps FixYa,
Chris
Sep 09, 2009 | Computers & Internet
Computers & Internet Logo
104 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
