Question about Hotpoint Aquarius WF000 Front Load Washer
My drum will not spin
My machine will let water in but my drum will not spin at all.
  • 35 Answers
Check the pressure switch its may be faulty
Posted on Jun 06, 2010
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Spin cycle does not fully spin out water
The drum might be too full and thus too heavy to spin out all of the water. Many machines have a system like this to stop the drum coming off. Take out some of the load and try again.
Feb 03, 2010 | Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
    you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
    Nov 05, 2008 | Washing Machines
    Hotpoint Aquarius WF000 Front Load Washer Logo
    61 people viewed this question
    Top Hotpoint Washing Machines Experts
    Todd Arndt
    Todd Arndt
    freddyfox
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
