Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Bosch Dishwasher Model SHU66C soap door will not open
    Genius:
  • 1,036 Answers
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Posted on Jun 06, 2010
We have a 16 month old Bosch SHE 4AM15UC/01 model dishwasher. The soap dispenser doesn't open most of the time. Does not seem to be dirty or clogged. Any thoughts?
Check the soap door for free opening. No friction in the hinge. Otherwise there may be little alignment problem. You may have to access that the rely latch area and adjust !!
Oct 04, 2010 | Bosch Dishwashers
My Bosch SHU66C is not filling with water. Timer
HI. First you will need to make sure you are getting water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you are receiving water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case the valve should be inspected and replaced, if needed. Us the procedure below to guide you through the inspection process.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
Apr 07, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Tried to replace bosch soap dispenser model shu3036uc/u12
Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
Dec 28, 2017 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
560 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
