Question about Brother MFC-7420 Laser Printer
Drum maintenance - Brother MFC-7420 Laser Printer
  • jray384777 Jun 06, 2010
    on the screen the message is "drum maintenance needed" refer to owners manual. I did that.
    I cleaned drum unit with rubbing alcohol with cotton ball. no positive results. any more suggestions?
    THANKS FOR THE INFO, I WAS JUST FOLLOWING THE INSTRUCTIONS IN THE OWNERS MANUAL. IT SAID TO CLEAN WITH ALCOHOL.
    THANKS
  • 526 Answers
I;m not sure what your question is, but if your getting a drum error, it could be one of 2 things.
1. you need to clean the wires on the drum, there is a purple tab that slides back and forth that cleans wires.
2. you need to replace the drum. take the toner cartridge out of the unit, separate it from the drum, replace the drum, re-attach toner cartridge to the drum, and re-insert the toner back into the printer.
thanks
Posted on Jun 06, 2010
  • adi Jun 06, 2010
    by cleaning the drum with alcohol, you ruined the drum.
    if you did not do option #1, then you will need to do option #2
    i dont know how well the drum will work with the way you cleaned it, thats not supposed to happen.
Video for replacing front brakes pads and rotors on a 2004 ford e
ccr20011001bb00.jpg Brake Bleeding
Purging air and moisture from your binders
CarCare - Maintenance - Brakes
ccr20030701as00.jpg ABS Speed Sensor Service
A clean sensor is a happy sensor
ccr20030701db00.jpg Drum Brakes - Rear Brake Drum Adjustment
It's stupid not to adjust your rear drum brakes
ccr20050201rr00.jpg Replacement Rotors
Friction, brake rotors, and you
ccr20050501pb00.jpg Power-Bleeding Brake Systems
Air today, gone tomorrow
ccr20050701bp00.jpg Replacing Brake Pads
How to replace worn pads
ccr20071101bs00.jpg Bleeding Power Steering
Getting rid of that air in there
CarCare - Maintenance - BrakesThanks
May 29, 2010 | 2004 Ford Escape
Error code 07.009.42 what should I do?
07,009.42 Error indicates that the printhead was unable to tilt normally on its axis.
This is most likely caused by a cracked drum maintenance camshaft. The drum maintenance camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about US$20 from Xerox but can be very difficult to replace. Also look at the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If the drum maintenance pivot plate is white plastic it should also be replaced with the new style black plastic plate. This requires removing the process drive gears assembly. Note that reinstalling the assembly requires the gears to be accurately timed. This repair should only be performed by a qualified technician.
Mar 24, 2010 | Xerox Phaser 8400 Laser Printer
My e-studio 45 has 260,000 copies and says it needs maintenance. It works well. Do I just replace the drum or does it need other parts like a fuser too?
Hello sir; When it said need maintenance, it means need PM( periodical maintenance) that including drum, drum blade ,developer, corona wire, etc. the fuser and pressure roller depend on condition.
Feb 01, 2010 | Toshiba e-Studio 45 Black and White Copier
XEROX PHASER 8550 PRINTS ONE PAGE AND JAMS THE SECOND - DID TESTS AND PAPER PATH TRAIL EDGE AND PAPER DRIVE POWER BOTH FAIL, CAN YOU TELL ME WHAT PART IT MIGHT NEED...THX
Is the Drum unit clean?
Often the Drum Maintenance kit can get dirty, and not clean the Drum properly, which can lead to jams.
Also, the drive cam for the Drum Maintenance kit can fail. This means not enough cleaning pressure is applied to the Drum unit, and it can't clean it properly, causing jams.
good luck
Dec 23, 2009 | Xerox Phaser 8550DX Laser Printer
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Hallo
07,009.42 indicates that the printhead was unable to tilt normally on its axis.
You probably have a cracked drum maintenance camshaft. If the drum maintenance pivot plate is white plastic it should be replaced as well with the new style, which is black plastic. This repair requires removing the process drive gears assembly and reinstalling it requires the gears to be timed. This repair should be performed by a qualified technician familiar with these machines.
You probably have a cracked drum maintenance camshaft. The dm camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about $17 from xerox but can be tricky to replace if you're not mechanically inclined. The other thing to look at is the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If it's white it will also need to be replaced with a black one.
Oct 15, 2008 | Xerox Phaser 8400 Laser Printer
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
Maintanance kit replace
Problem:
Cause:
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Gapped incomplete printing of text and pictures
Try this:
1. drum refreshing- set A3,or A4 paper in the multipurpose tray.(bypass) press the * (asterisk) key
on the control panel. Then select drum refreshing.Select "ON".
2. Check the Drum Cleaning blade-clean it,
Drum can be cleaned with alcolhol,if copy quality is bad after that perform several drum refresh procedures.
3.Time for maintenance is just info for customer that machine has declared maintenance interval.
Customer must check Warranty terms and conditions.
resseting time for maintenance: enter 10871087,then select U251, press start.To clear,press clear key(yellow button)
and start.After that,press stop key twice,and enter 001 and start.
4. Also I suggest to clean grid on main corona.
Sep 26, 2007 | Kyocera Mita KM-2530 Laser Printer
Brother MFC-7420 Laser Printer Logo
244 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
