Question about Toshiba Satellite P205D-S7436 Notebook
I have a toshiba Satellite P205D-S7436 with a power problem ( the ac plug or the battery) i get no lights, and it wont turn on. I have switch the ac cords and the battery, still no luck. I am at a lost any help. mike
  • 76 Answers
Motherboard is dead... contact tech support
Posted on Jun 06, 2010
I need to know if the mother board from the p205d-s7436 is compadable for the s7438 model
Satellite P205d-s7436 motherboard,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,K000056150.aspx
Satellite P205d-s7438 motherboard,
Same part number used for both laptop models.
Satellite P205d-s7436 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7436/4505-3121_7-33428376.html
Satellite P205d-s7438 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7438/4505-3121_7-32658635.html
Just by comparison of the specs the data suggests only a Processor change, Ram Memory amount, and Harddrive size.
Uses a Socket S1 processor socket on both model's motherboards,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29
Both models use an AMD 690V graphics chipset, (ATI Mobility Radeon X1200)
http://en.wikipedia.org/wiki/AMD_690_chipset_series
The answer is Yes.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Regards,
joecoolvette
Sep 15, 2012 | Toshiba Satellite P205D-S7438 Notebook
Toshiba satellite p205d-s7436 will not start.
Please remove the cable and remove the battery and connect the power cable and check it. if it working remove the power cable and connect the battery and check it.
Mar 15, 2012 | Toshiba Satellite P205D-S7436 Laptop DC...
Toshiba P205D-S8802 will not start up. Pressed power button, and hear the droves starting up and then stops. The screen remains black.
Hopefully you have more than 1 stick of RAM. I would remove 1 and try it again, if that doesn't work, try the other one. When it's powering up and then powering off quickly, that could also be a heat issue. Make sure all of the fans are powering on. Also you can try removing the battery, and trying with just AC power connected. Some laptops won't let you do this, but some will, and if the battery is causing the issue, it should work.
User guide can be found here, which will walk you through getting to the memory bay. http://www.retrevo.com/support/Toshiba-P205D-S8802-Laptops-manual/id/12395ag000/t/2/
If this helps, please provide a positive rating.
Jun 30, 2011 | Toshiba Satellite P205D-S8802 Notebook
Screen dim after a few minutes of running.
If its on battery then it may be set in control panel/power settings to dim when the batery is low.
Try to adjust the settings to max.
When it dims if you move the lid or very gently flex the lid does it change?
may be a loose connection loosing contact when it heats up
Jul 10, 2010 | Toshiba Satellite P205D-S7436 Notebook
No power what so ever toshiba satellite p205-s8804
I have the same hunk of junk with the same problem. Totally dead. I replaces the battery and the charger is fine. HELP!!!
May 11, 2010 | Toshiba Satellite P205D-S8804 Laptop
Freezing up
Try making sure that you plug jack into computer first and the the wall.
Mar 11, 2010 | Toshiba Satellite P205D-S7436 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Power supply issues, wont charge.
Dear,
This is isse with your power adaptor. Its not having the capacity to light up the scree while working. But it is having the capacity to charge you battery. You have to replace your power adaptor
Oct 13, 2009 | Toshiba Satellite P205D-S7479 Notebook
Toshiba Satellite P205D-S7436 Notebook Logo
236 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
