Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 washing machine wont let me go into a program keeps beeping, when i press a program just displays ''on''
  • 35 Answers
Main pcb may be prob or rat bites inside the machine
Posted on Jun 06, 2010
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Hotpoint wt960 keeps displaying f05
Seems that the pressure switch is jammed and so it does not cut off supply or is cutting off inlet water to the washer. Remove the lines to the pressure switch and reset, check the pressure switch diaphragm
Click pressure switch
Error codes for Hotpoint
Jan 20, 2013 | Washing Machines
How can I release chid lock on hotpoint ultima wt960
The Child Lock button is the second from the right in the line of buttons below the LCD screen. Press and hold this button for at least 2 seconds (or until you hear the beep and the icon light goes out). With a number of appliances, I've found that it takes longer than indicated to release a child lock so hold the button until you hear the beep.
The manual for the Ultima WT960 is available here: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf . See the bottom of page 18 for the child lock toggle information; the picture of the washer option buttons is on page 9. Use the Adobe Reader Zoom to see the keys (at step 5 of the Starting a typical wash programme). Other Hotpoint appliance manuals are available here: http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do .
If the lock will not release, then you may have a problem with the keypad or the controller.
I hope this helps.
May 10, 2012 | Hotpoint Washing Machines
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
My washing machine wont work at all since we canceled a cycle halfway throughthe model is hotpoint ultima wt960
Press pause cancel several times, or unplug the washer for 20 minutes.
--W/D--
Aug 18, 2009 | Washing Machines
My hotpoint wt960 keeps saying test HELP
turn the machine on whlile pressing the start and on buttons at the same time.hold until 'dOFF' appears.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have just fitted a new door lock on my washing machine hotpoint wm53p and now it wont work.
How do i replace the door handle on my hotpoint washing machine (wt960)?
Jul 21, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
300 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
