Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Water line routing
Need complete water line routing diagram for bissell power steamer pro
  • 14 Answers
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Posted on Jun 07, 2010
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Need the water bottle,for pro heat platinum POWER STEAMER BISSELL
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
mn./
Nov 04, 2009 | Bissell 1699 ProHeat Clear View Upright...
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Power Steamer Proheat Plus not dispensing
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
How to put automix piston back in place of a Bissell Power Steame
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Jun 18, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
445 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
