Question about Candy AQW130 Front Load Washer / Dryer
My washing machine is Candy C435 T model.when i am filling the water it goes out directly without filling..Why?
  • Candy Master
  • 3,463 Answers
Possibly the drain outlet is too low.
Try raising the outlet hose to a higher level, this will stop it syphoning out as it is filling.
Posted on Jun 06, 2010
I have bought a candy washing machine it has filled with water now coming up with error code e03 how am I meant to take the filter out when its full with water ???
Problem with drain circuit, usually something stuck in pump.
It should have a warranty phone company you purchased from they should sort it out then.
Oct 31, 2016 | Candy Washing Machines
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
I have a candy ciw 100t washer dryer and the water never gets hot, is this a cold fill washing machine?
to find if this is a cold fill machine only, just check the back and see how many hoses are fitted to it.I would assume it is cold fill and the problem is within the heater.
Mar 15, 2010 | Candy DQW150 Front Load Washer / Dryer
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
Oct 30, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy cm1126
although not famillar with your particular model. if its filling with water when not even turned on you have a bad water inlet valve.no servicing just replace
Mar 13, 2008 | Candy CN146 Front Load Washer
Candy AQW130 Front Load Washer / Dryer Logo
311 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
