Question about Philips CDR800 4-Disc CD Recorder
Cdr drawer won't open on Philips cdr 800.
The cdr drawer won't open. It worked fine for many years, but recently tried to record music and discovered that the cdr drawer wouldn't open no matter what buttons were pushed. Tried unplugging, putting it into standby mode, pushing fast forward/reverse buttons simultatneously, putting it into demo mode. Nothing worked. I hear no mechanical clicking or other noise from that drive. The play carousel works fine.
    Problem Solver:
  • 10 Answers
Looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Posted on Jun 07, 2010
  • Al Hutama Aug 08, 2013
    Philips CDR 800, is not a computer, how can we download a repair tool?
Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Dec 06, 2012 | Audio Players & Recorders
Phillips cdr 200 recorder, just recorded 13 tracks with time left over on sony brand recordable cds for music. i switched from analog to digital to finalize and it took 4 mins however RECORDABLE still...
It sounds like it didn't truly finalize. Try finalizing it again since the 'recordable' status implies it still qualifies. You have to press RECORD immediately after FINALIZE.
The Philips directory lists a few CDR200 models but the documentation contains directiosn for CDR765.
http://www.p4c.philips.com/files/c/
for example...
http://www.p4c.philips.com/files/c/cdr200bk/cdr200bk_dfu_aen.pdf
If for some reason you ever want or need to extract music from a non-finalized CDR or CDR-W, try loading it into a standard DVD player. Without a TOC the player won't be able to display track info or navigate to individual tracks but it MAY play it straight through anyway and you could digitally capture all or part of the output on another CDR. Just be aware that if the original is rewriteable and has old data beyond the new data you will crash into it without warning at the end of the new data, so be ready to pause your copy at the appropriate time.
Apr 07, 2011 | Philips Audio Players & Recorders
When i put a balank cdr the recorer says wrong
Listen to it. Go out and buy "CD-R for AUDIO" or "CD-Music" blank CD's and it will cooperate. Home CD recorders are designed to reject data CD-R media for recording.
Jan 22, 2010 | Philips CDR775 2-Disc CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Wrond Disc
The disc you need to use to record is "PHILIPS CDR MUSIC". That is what it should day on the top of the disc. On the left side of the disc, it should say "DIGITAL AUDIO RECORDABLE". I spent a lot of money buying the wrong discs before finally finding the correct one. So I know your frustration!
Apr 05, 2008 | Philips CDR600 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Philips CDR800 4-Disc CD Recorder Logo
634 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
