Question about Target Pro 35 Iii 26S Wisconsin Gas Engine Horsepower: 35.Blade Guard Capacity:30
Wisconson v4hd no spark from the magnito. disconnected the kill wiring.replace points & condensor.what else can i look for inside the magnito?
I have no spark on my 1969 Honda 90 passport moped any help??
I believe that this moped has a magnito and it is probably not functioning
Jun 09, 2014 | Cars & Trucks
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
I just got new points for my 1977 yamaha xs400. My old ones were pitted and burnt. Now I can not get it to start. My old ones just did not give the spark i needed. I also got a new condensor. The new...
The gap should be .015 with the points arm on the high point of the cam. There is a chance the new condensor could be bad from the factory. Not very likely, but remounting the old condensor would eliminate that as the problem. Is there any chance the wires are disconnected or broken anywhere? Use a multi meter to check for power at the points. Have you checked the fuse box? Is the Kill switch on? Check the side stand kill switch also if your bike has one. Good battery? Install new spark plugs. Carbon buildup on the plugs can rob electricity needed for a spark. Please rate my answer. Thanks.
Aug 20, 2010 | 1980 Yamaha XS 400 Special
Lawn mower not sparking any ideas
pull the wire going to kill switch - recheck for spark if spark grounding switch, if no spark
pull wire off the coil retest if no spark faulty coil indicted
but be sure that unit is not a point model coil 1st
if a point model coil you will see a approximatly 10 mm gap on either side of coil winding and armature legs where it mounts
if briggs coil that is , if so most likely point and condensor need replacing
but if a magnetron coil unit then magnetron is faulty
replace it & set air gap to 0.010 " and reconnect kill wires
cheers paul
Aug 10, 2010 | Garden
Stalled out does not seem to get spark
First, you must find out if your getting spark or not. Remove plug, and ground it to the motor and pull cord, see if your getting spark. If you are, then your problem is your not getting fuel. If your not getting spark there are a couple of things that can cause this. !st, defective spark plug, Second, cable from control handle to engine may have stretched and is not releasing the kill switch. Disconnect the kill switch wire and check to see if you have spark, if you have spark, replace engine control cable. If with kill switch wire disconnected you still have no spark, you would have a defective magnito coil, which is rare, but does happen. This engine control cable kills the spark when you release the handle and also is the engine brake, It serves two functions.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
OUr murray lawn mower will not make spark at spark plugs. Help
check all your kill wires first to see if they are touching ground somewhere.
then check magnito/coil for power to it
disconnect kill wire at magnito if there is power to it.
if not .... you need a new magnito
May 21, 2010 | Briggs & Stratton Garden
Taking coil of the engine on snoblower toro 8/32 briggs/stratton I don't have the manual for this engine and i need to replace the coil but there is a wire that i have to unplug but it seems to go inside...
that wire goes to under the flywheel which goes to the condenser and points which is probably the problem in the first place the condensor goes bad first before the coil very seldom does the coil go bad few bucks for a condensor and points comparred to big bucks for a coil you have what they call conventional points and condensor not electonic ignition but you can just buy a new electronic ignition coil and just yank the wire from under the flywheel then put your kill switch on the new coil set your gap with a business card from the magnet and the coil and your set
Nov 04, 2009 | Garden
No spark
if you have no spark and a good plug then you have a bad magnito it is what your plug wire comes from and it is mounted next to your fly wheel or fan the part that the pull cord is attached to it creates the spark every time the maganets on the flywheel pass it it could also be out of adjustment also it needs to be very close to wheel without touching it i would try and adjust it first loosen the screws on the magnito and slide a piece of high quality printer paper between the wheel and magnito then tighten it down then pull your paper out if you can not then you need to move magnito back more you want the paper snug in there but able to pull it out now after doing this spin the whell around and make sure there is no touching between parts now check for spark oh make sure magnito is not to far away if you can slip a buisness card between the two you are to far apart if you still have no spark replace magnito but check the plug wire first make sure it is good good luck briggs are good motors you should be able to get part s without trouble also
Jun 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
NO FIRE ON KOHLER 12.5 OHV MOTOR
All wires on a small engine except for the spark plug wire are to ground out the spark and stop the engine. Except a few for accessories and on generator/welders.
Knowing that, there is a small main wire that comes from your coil and leads to all other wires. It usually sits under your gas tank and runs toward your on/off switch or ignition switch. To see if it is any off your shutdowns gone bad, disconnect this wire. If still no spark then you either have a open in this wire or your magnito (coil) is bad.
If it starts, then unplug all the wires going to the kill wire and hook them up one by one until you find the one that kills the engine. Follow the wire to it's source looking for breaks in the line. If no breaks then the switch is out of place or bad.
Note: check your oil level first. Most engines come with a low oil sensor that will kill the spark if the oil level gets too low.
To check is your magnito is bad or you have a short, disconnect the wire at the magnito found by the flywheel under the flywheel cover. Tuck this wire out of the way and try to start your unit. No spark then you have a bad magnito.
Apr 01, 2009 | Briggs & Stratton Garden
Intermittent spark, new spark plug, no start mcculloch chain saw cs 38cc smh038ub24ra em. u.s. epa ph-1, 95-98 ca. emissions regulations for ulge's. d048
Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of the way. Reinstall your cover than start the saw. If your spark remains constant you have a short in the kill circuit or something is bent or misaligned between the off switch and the kill wire. If you still get intermittent spark, your magnito is going bad.
Mar 31, 2009 | McCulloch Garden
Target Pro 35 Iii 26S Wisconsin Gas Engine Horsepower: 35.Blade Guard Capacity:30 Logo
70 people viewed this question
Top Target Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Target Measuring Tool and Sensor Expert? Answer questions, earn points and help others
