Question about Alesis Sr 16 Stereo Drum Machine
Drum sound distorted
I have an alesis sr16 drum machine and the sound has now become distorted have you any ideas on how to fix this problem.
thanks pat.
  • Alesis Master
  • 5,603 Answers
Try a factory reset:
drum sound distorted - alesissr16logo53x41.jpg Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Posted on Jun 06, 2010
    How do I reinstall preset patterns
    According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
    Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
    Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
    Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
    Also check for "polarity" (which part of your plug is + or - ).
    Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
    I have an Alesis SR16 drum machine. It fires up ok and you can select a drum pattern, but the output is barely audible. Only by bringing the volume on the machine and the amp right up can you hear anything...
    What power adapter do you have on this? This one REQUIRES and AC input, NOT a DC adapter !!! Many people try DC adapters on these because they lose the original and ALL fail. You need a 9VAC at 830ma or more adapter. If you have lost yours, search for "SR16 power adapter" to find replacement.
    Apr 27, 2011 | Alesis Sr 16 Stereo Drum Machine
    Only distortion..
    Check your power adapter. This unit REQUIRES a 9 volt AC adapter, NOT a DC one... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound generation with a DC adapter. This is a common problem as people try to run these on a DC adapter.
    Here is a link:
    http://cgi.ebay.com/AC-POWER-ADAPTER-Alesis-HR16-SR16-D4-DM5-/380178938839
    Apr 10, 2011 | Alesis Sr 16 Stereo Drum Machine
    Output section of PCB appears a bit fried as there is no sound output and there is a hint of burnt electronics. Rest of the SR16 works fine. I believe someone reversed the audio cable connections which...
    This is your best bet:http://www.alesis.com/content1024 It will be hard to find a schematic. Here is another link:http://www.ionet.net/~tslade/sr16.htm
    Aug 25, 2010 | Alesis Sr 16 Stereo Drum Machine
    Sound output is heavily distorted.
    Check following things:
    1. The master volume control on the SR16 is at least half way up. Turn down the amp as needed. Running very low output of the SR16 and high amp gain is sure to get distortion.
    2. Check power adapter is the original and is producing correct voltage.
    3. Check that audio cable is high quality instrument cable and not consumer or speaker cable.
    May 05, 2010 | Alesis Sr 16 Stereo Drum Machine
    I can't find a rotary pot for alesis sr16
    Try WD Greenhill.com. They were really helpful when I've needed hard to find parts for synthesizers. Let me know if this helps.
    Jan 18, 2010 | Alesis Sr 16 Stereo Drum Machine
    How can I put a walz beat in the Alesis
    Page 59 Odd time signatures of the owners manual explains how to do this. Type Alesis SR16 manual into Google and you can download a copy from media.zzsounds.com Please rate this if it helps. You can also download documentation here:http://www.alesis.com/sr16 under DOCS and Downloads
    Oct 29, 2009 | Alesis Sr 16 Stereo Drum Machine
    The tempo indicated on the alesis sr16 is inaccurate
    how can i change the tempo on song compose, for example step 01 tempo 60 and step 02 tempo 120??
    Thanks.
    Jan 16, 2009 | Alesis Sr 16 Stereo Drum Machine
    Alesis Sr 16 Stereo Drum Machine Logo
    510 people viewed this question
    Top Alesis Music Experts
    drivealot
    Lawrence Oravetz
    Robert Graf
    Are you an Alesis Music Expert? Answer questions, earn points and help others
