Question about Sears Exercise & Fitness
We have a trainium by dp model 7600 sa
The belt is slipping and moving to the right.
2 Suggested Answers
mark24354
  • 776 Answers
SOURCE: How do I adjust the
I don't have access to the Trainium 7600 but most treadmills would require a socket or allen wrench to tighten the bolt near your right toe (just before you step forward onto the treadmill. Turn it 1/2 turn then test it. repeat several times until the belt stops moving to the right. If, after any adjustmet, the belt starts moving to the left, turn the right bolt 1/4 turn counter-clockwise and try again.
If your whole mat is loose (any slippage is detected), you can turn the bolt near your left toe AND the right two 1/2 additional turn.
Sorry but you will have to check yourself what type of bolt size you need. Most treadmills ship with an allen wrench or similar adjusting tool for the bolt. They usually get lost before the first adjustment is needed at 1000 or so.
-Mark
Posted on Jun 07, 2011
Panasonic sa ak20
I have said before that the belt is only the tip of the iceberg. Now you need to have a Technician work on it. I am not being mean just truthful.
Feb 05, 2014 | Audio Players & Recorders
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feels like belt is slipping when in use. Would
tighten evenly until it stops slipping when your on it
Oct 15, 2009 | Exercise & Fitness
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Removal of the top on a maytag model 7600.
TO GET THE TOP OFF, YOU MUST REMOVE THE FRONT PANEL BY TAKING OUT THE TWO SCREWS BY THE DOOR HINGES AND THEN THE TWO ON THE OPPOSITE SIDE. THEN REMOVE THE FRONT PANEL. THE TOP IS HELD DOWN BY TWO METAL HOOKS THAT ARE SECURED BY ONE SCREW EACH. THIS SHOULD GIVE YOU ALL THE ACCESS YOU NEED TO CHECK THE BELT.
Dec 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Exercise & Fitness Logo
449 people viewed this question
Top Sears Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Sears Exercise and Fitnes Expert? Answer questions, earn points and help others
