Question about Maytag MGR5770 Gas Kitchen Range
There was a power outage. When the power came back on the LED display was dark and when clock or timer is pushed, the only thing that is displayed is ''OFF''. The Model # for this Maytag Range is MGR5770ADW, S/N 13120496US. The temporarily lit display suggests there is power getting to the range and the stove top works fine. Any suggestions?
  • lesstehmeier Jun 06, 2010
    This solution worked perfectly!! Thank you Ginko!!! This is a great site and I am amazed how fast the response was.
  • Maytag Master
  • 19,396 Answers
Hi.
The range is control locked.
Hold down the Control Lock pad for five seconds to unlock the unit.
If that does not work, disconnect power for five minutes, connect pack and try holding the control lock down again.
If still no luck, then there is a fault, either a faulty oven electronic control or a wiring problem.
Usually you get the appliance back to work simply by holding the control lock pad down for several seconds.
Regards.
Ginko.
Posted on Jun 06, 2010
  • Ginko
    Ginko Jun 06, 2010
    Hi.
    You are welcome.
    Thanks for the nice feedback, have a great day.
    Ginko.
The display is dark
Not enough information.
Is the unit receiving power and do you have a power LED ?
Is your power connection to a surge protector or power cube.?
How old is the unit ? Has it been dropped or in a electrical storm or outage ?
Feb 04, 2014 | Sharp Lm64p122 Lcd Panel Module Industrial...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Team sports america scoreboard clock has no display after a brief power outage
Their is a 3.7v button battery inside,it will cause the display to fail when it is dead,it was discharged after your power went out.Replace the battery and it will work again,I have done this.
Jul 14, 2012 | Audio Players & Recorders
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do you get the clock to operate on a battery only (uses a 9V). I insert the battery, then unplug the clock. The display is dark. But when I plug it back in, it is on the right time. If there was a...
They're just used to retain memory. That's all. Once power comes on, the time should be correct. Now if the power went out and there was no battery on the clock, when the power comes back on it goes straight to flashing 1200.
Jun 28, 2011 | Westclox 181961 Omni II Clock Radio
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
The LED display is dark
The display is dark most probably the the negative voltage which is required to turn the display is damaged. We need to trace it at the power section
Aug 10, 2009 | Bose Wave Radio
Having trouble with the clock display
try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Jan 22, 2009 | Whirlpool RBD305PD Electric Double Oven
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Nov 23, 2008 | Bose Wave Radio
Display area and clock will not re-set on Electric Range
on any appliances need to know the model and serial num some problems are model specific
Dec 28, 2007 | Kitchen Ranges
Maytag MGR5770 Gas Kitchen Range Logo
42 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
