Question about Coleman Boating
I have 2 punctures in my raft. Can I use a regular rubber repair kit?
  • 76 Answers
Coghlan's Plastic or Rubber Repair Kit works on air mattresses and raincoats so it could work on your raft. It is available at Canadian tire for about $4. In a pinch you could also use duct tape. It provides a temporary, but waterproof seal.
Posted on Aug 05, 2010
Fiat punto radiator coolant leaking
could be coolant pipe or radiator its shelf has been punctured, you'll need to locate the source if its a the radiator then your aswell to replace the radiator. if its one of the pipes the you may be able to patch the puncture with solution or rubber repair kit
Mar 29, 2013 | Fiat Punto Cars & Trucks
Tip
Tip on tools you may need while fixing a flat tire.
You need A pump. <br />A puncture repair kit containing:<br />Tyre levers (at least two, preferably three) <br />Rubber patches <br />Rubber vulcanising solution (glue that sticks rubber together) <br />A small piece of sandpaper or other rough material <br />A crayon <br />You might also need:<br />An adjustable wrench <br />A talcum block (the small grey block included in some kits) or small bag of talcum powder.
on Dec 21, 2010 | Cycling
Raft repair
Sevylor sells a patch kit, as well as a spray that is kind of like a silicone that works well on pinholes. Go the website: http://www.sevylor.com/Spare-Parts-Kit-P1898C45.aspx - more parts under accessories on the site.
You wouldn't have a copy of the manual for your boat, would you? I can't seem to find one - even called Sevylor and I couldn't get one!
May 15, 2012 | Sevylor Fish Hunter 6 Person Inflatable...
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
I need my inflatable raft repaired i live in new york city where can i go to get it fixed.
You can actually save a BUNCH of money and do it your self its really easy go to a sporting good store or online and look for a raft repair kit takes a couple hours including dry time and costs less than 20 bucks
Apr 15, 2009 | York Yankees Full Size Pool Raft Float!...
The rubber ring/seal has been punctured
heardof people repairing with limited succes with bicycle tire repair kits, the true solution would be to replace theboot, can be a abit of a pain in the but to get on but with time and some patiens it cann be done aprts problay 75-90 bucks
Mar 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Boating Logo
244 people viewed this question
Top Coleman Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Coleman Boating Expert? Answer questions, earn points and help others
