Canon fax l100 .........problem error100.........help me and thanks
  • 5 more comments
  • Lebanon Raingam
    Lebanon Raingam Jun 06, 2010
    Please let me know the problem, how does that error100 comes out? Is it during scanning or when you switch on the machine? Let me help you.
  • lordman1981 Jun 06, 2010
    The problem appears sometimes or upon separation of the feed device and re-Link
    The problem appears sometimes or upon separation of the feed device and re-Link..........please now
    Please help me Is there a solution to the problem one way or another I hope to benefit
    I will try all means to resolve this problem, but I want to help you
    I want to help you to solve my problem with this fax only to change this is the intent of my words do I find the solution?
    Thank you, but is there a way to re-create the fax to factory settings does the factory reset solve the problem
  • 4,737 Answers
This error means the receiver cannot receive the file properly due to poor line signal or conditions. If there's a feature that you can adjust the transmission level, try to boost it. You also need to set the speed 4800 bits per second. There are many solutions, but they can only be implemented by the technicians. This error also signifies that the receiver's machine isn't receiving the file/data because of low transmission level. If you can set the echo counter-measures, that'd be very helpful. Also try to dial the receiver's number slowly, sometimes this helps. I am sorry that I can't provide you more than these information since you'll not understand even if i do. If you insists, i'll do it for you. Good luck. Thanks for using FixYa.
Posted on Jun 06, 2010
  • 1 more comment
  • Lebanon Raingam
    I am sorry I can't understand when you say "but I want to help you". If I am right, I am the one who is helping you, not you are helping me.. :-D..
    Anyway go ahead and let me know.
  • Lebanon Raingam
    Ok... let me post the solution here... but note most terms are only technical terms which is very difficult for ordinary people to understand. No problem you can try;
    A. Cause: (Q signal transmission after picture signals); The other party cannot receive picture or Q signals properly due to poor line conditions.
    Solution 1: Boost the transmission level so that the other party can receive picture or Q signals properly.
    Solution 2: Lower the transmission start speed to 4800 bps.
    Solution 3: Adjust the NL equalizer so the other party can receive picture or Q signals properly.
    Solution 4: Add an EPT on the V29 modem signals.
    Solution 5: Adjust the continuous transmission time of 1 before transmitting the picture signal so the other party can receive picture signals properly.
    Solution 6: Lengthen the no-sound time after receiving CFR so the other party can receive picture signals properly.
    B. Cause: (After TCF transmission before picture signals); The other party cannot properly receive due to low transmission level.
    Solution: Boost the transmission level so the other party can properly receive the signals
    C. Cause: (After TCF transmission before picture signals); The other party experience echo malfunction.
    Solution 1: Take echo counter-measures as described in Service manual.
    Solution 2: Press Start button after confirming the first DIS from the other party during a manual call.
    Solution 3: Add a long pause after the telephone number when registering the user in the auto- dialing directory so that the system will not respond to the first DIS from the other party.
    Good luck.
  • Lebanon Raingam
    There are some reset tricks, but I am not sure whether it will work for your machine or not. No particular resetting measures for the model. You can try this..;
    Hold the menu button and #, press down the screen using the up down key and select "start" or "Copy". Note that you have to hold the menu and # while doing this otherwise it'll not take affect.
    Good luck.
On our cabnon l100 we are trying to send faxes. After entering fax no. we are getting message saying *Memory* Set Doc - but fax does not go - what have we done wrong?
try to check the memory of your fax, their might possible that the memory is full and need to clear them. Just a thought hope it helps thanks.
Sep 15, 2011 | Canon FAX-L100 Plain Paper Laser Fax
Fax L100 codice errore durante rx 0033
Information from service manual Canon L100:
Error Code 0033 :DCN was received through a non-normal procedure
Jan 18, 2011 | Canon FAX-L100 Plain Paper Laser Fax
FAX MACHINE CANON L100 ,RX ONLY BLACK PAPER?
Change toner,it may be damage.So you can change.
Dec 14, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | Canon L120 Fax Laser Printer
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
I've got error message on fax-l100 canon
I have been having the same problem from my cannon l100.
If you switch off the fax machine for 30min the switch it back on again the fax will resets its self and will clear this error.
Martin
Jan 31, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon L100 Service mode
can't help with service mode, but what makes you think a white balance error?
Jan 17, 2008 | Canon FAX-L1000 Plain Paper Laser
352 people viewed this question
k24674
jasbo
jasbo
