Question about Neff 3.80 cu. ft. / 108 liter Upright Freezer G4344
What do the three buttons mean at the top of our neff freezer
We would like to know what the three buttons mean at the top of our neff freezer. Not usre of the model, but we bought it in 2006 an dit is the undeer the counter, integrated model. They all become illuminated if pressed. We are concerned that this is fast freeze, or similar, as the freezer is very cold. Ice cream is rock hard!!!
Thanks
Tom
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have an old lec freezer which seems to work okay although we get moisture on the outside of the appliance..
the moisture is just condensation from the room its in,(same as tiles in bathroom.)...cold surface warm air.
Oct 05, 2010 | Neff 3.2 cu. ft. / 91 liter Upright...
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
Freezer running bout only freezer top of freezer
Either the compressor is failing or it has lost some freon which means there is a leak. The sealed system needs serviced.
Eric
Sep 15, 2009 | Woods Chest Freezer C1501W3
Neff 3.8 cu ft freezer.
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Sep 10, 2008 | Neff 3.80 cu. ft. / 108 liter Upright...
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Neff 3.80 cu. ft. / 108 liter Upright Freezer G4344 Logo
688 people viewed this question
Top Neff Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Freezer Expert? Answer questions, earn points and help others
