Question about Briggs Stratton H7159 & Stratton® 5500, 10 HP Generator
Briggs and stratton 2200psi pressure washer no pump oil drain how do you changec pump oil
    Scholar:
  • 142 Answers
Try to turn it over or to the side of oil check.
Posted on Jun 07, 2010
  • parlapanov Jul 05, 2010
    Did you find it?
Why is there oil under my briggs and stratton 4hp pressure washer motor? (on the top of the pump)
pressure washers are unique in the fact they have two separate compartments for lubricating oil , one compartment holds engine oil and the other compartment holds pump oil/coolant the two compartments should never mix (bad idea) even though they both take similar type oils , sometimes the pump oil chamber will expand a bit with heat in use and a little oil will pop out a vent hole in top of pump , this is normal but if this is too excess its an indicator of larger problems (blown seal) both compartments should be ck'd before use every time for both level and clarity and causes fixed for any thing that's noticed , pressure washer pumps are very expensive to repair , with costs in the hundreds to thousands of dollars for seemly minor repairs ( nothings minor on them) and the oil is there way to keep cool and work ok for years
Jul 05, 2014 | Briggs & Stratton Garden
Oil type 2400psi
any hosue holdcar motor oil will work
Dec 31, 2013 | Briggs & Stratton 3000 PSI Pressure Washer
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
http://www.briggsandstratton.com/eu/en/
Jun 25, 2013 | Garden
How do I winterize a Briggs and Stratton pressure washer
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Nov 03, 2010 | Briggs Stratton 020273 Elite Series...
How do i put oil in my pressure washer and where thanks
gasoline-powered pressure washer needs oil in two places. The pump and the engine.
Please read your manual along with this information.
Also stop by small engine shop and double-check details.
First the pump: Pump is where you attach hoses.
-On side of pump is clear window you can see oil. Oil should fill about half way. Do not fill entirely.
-Open cap on top of pump.
-Pour oil in from top.
-Your manual should tell you which oil to use. 10-20 or 10-30 non-detergent should do.
The engine.
Look for oil cap on lower side of engine
Use regular 10-W-30 motor oil.
Don't over-fill. About half way up dip stick is about right.
Never turn gasoline engine upside down to drain oil, or oil will flow into carburetor.
Oct 06, 2010 | Briggs & Stratton Garden
Leaking at point of connection between tip and wand
There is a rubber o ring in a groove towards bottom of the snap in connector.This seals around the tip as you insert it. It will never seal without it. The ball bearings you mention are only to hold the tip in place. The sealing goes on down in the coupler
Jul 02, 2010 | Briggs & Stratton Briggs Stratton ORing...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Briggs Stratton H7159  & Stratton® 5500, 10 HP Generator Logo
142 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
