Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The motor keeps running and i cant open the door i tried to unplug it and plug it back in and still nothing I hold the unlock button for 3 seconds and it still doent release
    Scholar:
  • 56 Answers
This may not be the problem now but by the sound of the malfunctioning unit, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
Door will not unlock after being unplugged and plugged backnin
Hello Tina,
You have to press & hold the "Drain & Spin" button for 3 seconds in order to unlock the door, assuming that the tub is not full of water, otherwise the system will attempt to drain it first before unlocking the door.
Good Luck!
Rich Lilja
Apr 16, 2016 | Kenmore HE2 Plus Front Load Washer
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Electric Range Model Number: FEF365CGBD> The oven door is open and the lock is engaged. The lock light is flashing. I tried disconnecting power (from the main breaker) for about 10 minutes but that...
    . If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
    Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
    There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
    hold in the door button and push broil until the latch makes a 360 degree
    then the door lock should stop flashing and the oven will work again .
    Hold the lock button for 3-5 seconds..
    if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit.
    if still the same problem the door assembly is cracked and that needs replacement.you can get required parts
    from www.repairclinic.com
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Jan 17, 2010 | Kitchen Ranges
    F90 code flashing and i cant reset it
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
    Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven door won't unlock
    I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
    Feb 16, 2008 | Kitchen Ranges
    Kenmore elite 790.3670 oven door locked
    I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
    Feb 07, 2008 | Kitchen Ranges
    Control locked
    is any thing on or working check to make sure door is latched
    Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
