Question about HP Photosmart C6380 All-In-One InkJet Printer
Paper is loading crooked and causing a jam - HP Photosmart C6380 All-In-One InkJet Printer
    Problem Solver:
  • 18 Answers
Sounds like there is something that has fallen into the paper feed path. Shutdown printer, unplug power from back of printer, and remove paper. With a flashlight, inspect the area around the paper feed roller for any debris (one time I found a penny lodged on the left side of the roller) that might have fell inside path and for damage to rubber wheels. Ink can build up on rubber wheels causing the paper to misalign. This can be cleaned off with q-tips and 91% Isopropal Alcohol or Dilute. If debris is found and cleaned then reload paper into feed path, make sure paper guide tab is in position against paper source. Plug printer power back in, turn on printer and push the paper feed button. If that doesn't fix problem the only other solution is the replace the paper feed roller or buy another printer. Let me know if this fixes the problem or if you find another issue. Have a Nice Day!
Posted on Jun 06, 2010
Paper jam, but no jam + paper feed problem
check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
Dec 29, 2009 | Office Equipment & Supplies
I can't print anything as the paper feeds in crooked and jams
Perhaps there is still a bit of paper stuck in the machine from a previos jam? Follow the manual to clear a paper jam. Then "fan" your paper like a deck of cards before placing it in the feeder. Make sure the paper guide is not set too tightly causing the paper to not lay flat as it enters the printer.
Dec 05, 2009 | HP Office Equipment & Supplies
Two separate problems: Paper loads crooked and then jams printer. Unrelated issue is "no paper loaded" error message even when paper is loaded...Help!
You might had a bit of paper stuck in there. Look real close where the rollers are and see if there is maybe a address label or piece of paper in the path of the paper.
-=/ MLF /=-
Oct 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When it is time for printing the paper feeds in crooked and gets jammed.
You need to look down inside where the paper is loaded with a flashlight and mirror, That problem is usually caused by strange objects falling in where they should'nt be, stopping the paper. I've found jewelry, pens, screws, candy, wrappers, and lots of stuff. way down inside.
Oct 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Crooked Cpoies
Pull all of the paper out of paper tray and reload. More than likely you will find some sheets on the bottom that are folded at the corners. This will cause crooked copies and also jams.
Jan 14, 2009 | Office Equipment & Supplies
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
HP Photosmart C6380 All-In-One InkJet Printer Logo
224 people viewed this question
Seeker5211
Seeker5211
