Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Ford tractor 6610,6640 parts manual
I would like to get in digital form the Ford tractor 6610, 6640 manual with the OEM codes for all the parts of the tractor
Apllied park brake and a spring broke, need manual, part number, schematic to reinstall
Manual can be gotten in electronic form from sears at the searspartsdirect.com website (linked at end of post), where you can download manuals for lots of appliances, tools, etc. Flip up your tractor's seat and look for the model number sticker, should be near the battery if battery is under seat. You will need the model number (model, not serial) to find the right publications. When new, the tractor probably came with an owners manual and a parts manual.
Alternative: get your model number, google it and the term "parts manual," and you will probably get right to the info at several websites.
Amazon is a possible parts source, with some decent vendors and prices; I've ordered several repair parts for my 2009 YTS 3000, which is technically a model 917.289210. That should be the pattern for Craftsman model number: three digit number probably starting with nine, decimal point, six digit number. Note that my owners manual has a typo and omits last character of model number. Watch out for such printing errors; you might be actually looking at the correct publication but it's mismarked. Be sure to save a PDF copy of the manuals so you'll have them later. Craftsman Riding Mower Tractor Parts Repair Parts Sears PartsDirect
As for assembly, the parts views will be some help. Once you get the new part it might be pretty obvious. For example, there might only be one hole or hook relativley close by that other end of spring could attach to. In general, all the "parking brake" does is hold the foot brake pedal down in the applied postion, not much different from jamming pedal with a stick (no I do not recommend this method). Unfortunately, due to safety interlocks, you need the parking brake to work if you want to leave the seat while tractor is running, as you've probably discovered.
Jan 17, 2016 | Craftsman PYT 9000 26 HP 48" Yard Tractor
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
I need a service and parts manual for iseki 4320
i believe the iseki tractors are the same as a ford tractor so try a ford tractor dealer
Feb 10, 2015 | Vehicle Parts & Accessories
Rear end locked up FOUND a cotter pin in the drain oil Ford 8 n stanard transmission tractor 1950-1960
dismantle it.
inspect all parts. for damage or excessive were.
same with all machines.
inspect and measure parts as the FSM states
FSM is the factory service manual. good luck for 1950
join a tractor form ,we do not have one here.
Jun 18, 2014 | Cars & Trucks
Define diagnostic code code 116327
I found a couple of codes that may be the cause here is the first one and the seond right under it thay seem to point to the EGR or EVR valve pressure issues it might need replacing. this is the 327 code can't find more than 3 digits for a Ford error code
Electronic pressure transducer (EPT)/differential pressure feedback exhaust (DPFE) sensor/electronic vacuum regulator (EVR)
327 (O,R,M) EGR feedback signal is/was low - EVR or PFE
you might be getting 2 three digit error codes as Ford only has 2 and 3 digit codes form all the sites I've checked. a 116 code is this
Out of range Engine coolant temperature sensor (ECT)
I hope this helps some
Apr 25, 2014 | 1992-1993 LX and Sport Models Body Kit...
OBD P0134 code - Is this for the pre-cat or post cat sensor?
DTC P0134: Bank 1, sensor 1 refers to the upstream (closest to the engine) sensor. While after market parts will fit, if you put them on an oscilliscope, they don't always show the same wave-form as the OEM part. Ok, OEM is usually more expensive, but at least you know what you are getting.
Sep 01, 2010 | 2003 Honda CR-V
How to input ford 6000 radio cd code
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Mar 05, 2010 | OEM Systems Car Audio & Video
I'm looking for an owner's manual for the MTD OEM 190-180 twin bagger. Mine is missing some small parts and the manual. Most of the parts are there, but evidently a couple of small brackets and the bolts...
You can download a user manual & parts manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers from under the seat.
Jul 16, 2009 | Arnold Corporation Twin Bag Collect System...
Replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Mar 07, 2009 | Briggs & Stratton Garden
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
484 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
