Question about Mitsubishi HC5000 LCD Projector
Our Mitsubishi HC5000 can no longer project red but the other colors still work. What can we do to fix it? Thanks,
  • 75 Answers
What input are you using. If vga check the pins on the port of the projector or the vga cable may have a damaged bent/broken pin. component may have a bad cable.
Posted on Jun 07, 2010
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
My mitsubishi 60" screen turns on but has red-like waves. Is sound in background, but it shuts down, too. Anybody know what it might be. I just bought and moved it to my house two weeks ago. Worked fine...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
The screen turns yellowish
That is true, problem is as old as lcd projection. Suggest buying a dlp product. they don't color decay
Nov 26, 2008 | Mitsubishi HC5000 LCD Projector
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi HC5000 LCD Projector Logo
168 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
