Question about Sewing Machines
Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Pfaff Select 4.0 has looping on bottom of fabric. Have re-threaded 50 times. Lost half a spool of thread. Not picking up bobbin thread at all. Changed tension, changed it back. Trying to free motion quilt. Frustrated beyond belief.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Posted on Jun 06, 2010
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
How to attach free motion foot
Most free motion feet attach like the other feet.
It is creating "thread nesting" also called birdnesting. Could be several things:
1) make sure before you thread the upper thread, RAISE the presser foot so the thread will seat properly in the tension disks
2) drop your feed dogs before you begin to free motion
3) your free motion quilt foot, when lowered, should not rest on the fabric. (Be sure you are lowering your presser foot when you want to stitch!) You should be able to move the quilt sandwich easily under the presser foot. If the foot applies any pressure to the fabric, you may need to release the presser foot pressure (consult your manual). Or you are using the incorrect presser foot for your machine.
4) If none of the above, you need to tighten the upper tension AND
try this method before beginning to free motion stitch:
How and Why to Bring up the Bobbin Thread
Aug 09, 2015 | Sewing Machines
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
When in darning position, I get large loops on bottom of quilt during darning/free motion quilting.
with some machines the type of spool you use for the thread matters. try different spools.
Jan 25, 2015 | PfaFF Sewing Machines
Upper thread get s caught under the needle plate when free motion quilting. Forms a loop and the fabric can't move.
change the needle
clean under the needle plate & in the bobbin area for loose threads & lint
rethread the machine top & bobbin
Mar 16, 2012 | Husqvarna Sewing Machines
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
308 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
