Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD-14AT2 SS Dishwasher.
A ten year old boy sat on the open door. Now the machine leaks and door opens.What can be done?
  • 489 Answers
The door frame is bent and will need to be inspected if further damage is done.  It's possible to fix but if the dishwasher frame is bent, then it's a total loss.  The frame is not repairable or are there any parts for it.
Posted on May 02, 2008
LG dishwasher LD-14AT2
Check the alignment of the door with the top of the counter top. The latch must complete the locking feature in order to start the options like wash, rinse, and dry.
Feb 27, 2014 | Dishwashers
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
Leaking dishwasher
There are screws on the inside of the door on a lot of those try to tighten them down a little sometimes that can cause a leak.
Oct 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
EI error code.
e1 on any LG d/w means the water pressure is insufficient due to the wash motor being faulty and /or the capacitor connected to it.
take care.
Jan 01, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG Diswasher model LD-14AT2
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
Jul 29, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
199 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
