Question about Toro Lawn Mower With Toro Power Tools
I'm trying to remove engine from tractor,but don't know how to remove pulley from the shaft.
    Problem Solver:
  • 10 Answers
If it's like my older Bolens (made by Toro btw), it was a pain, because there is a big bolt at the bottom where the pully connects to the shaft. Finally broke it free, and the biggest problem was locking the shaft while I exherted pressure on the wrench... :p
Posted on Jun 09, 2010
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Trying to replace a drive belt on the tractor. The pin that keeps the belt on the transaxle pulley is so close I can't get the belt on the pulley. trying to follow instructions in the book but it is...
Have replaced the belt a few times on my 48". Don't know if its the same model you have, but here's the way i've found to do mine:
The front pulley can be easily removed and i slip the belt onto it while holding it up just before re-inserting the pulley onto the shaft.
The belt is first slipped over the rear pulley and kept in a straight line toward the front pulley without winding it around any of the holders or anything to give it the maximum length. Also the clutch pedal has to be pressed/held down while doing the install. To remove the front pulley: take the plastic guard off the top center of the motor revealing the large center nut; place large crescent wrench or soemthing to hold the nut and then loosen the center pulley bolt from underneath with socket. Pulley will slide off sometimes after a few taps downward w/ a wooden mallet. Note there is a slot inside the pulley shaft that lines up with a raised area on the motor shaft. don't overtighten when re-installing, maybe lube the bolt a little 'cause you may need to take it off again in the future.
Let me know if you need more details.
Thanks,
GT
Jun 07, 2011 | Craftsman 48" Cut Riding Lawn Mower Deck...
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
Howdo you belt pulley from the engine shaft on a 14.5 hp briggs i believe it has to be removed to replace front drive belt
I have not looked up your model to see if I can find an answer.
I think if I were faced with this problem, I would try to stretch the belt over the pulley before I tried to remove the pulley. I have tried both ways and stretching is superior to removing the pulley every time. I say so because you are going to have to get that darn pulley back on the shaft afterward and the belt will fight you every MM of the way. Plus you will be working in a confined space --- looking up --- in the dark --- on your back!
short out the plugs so the motor cannot fire -or at least disconnect them. Get the edge of the belt in the groove of the pulley then **** fingers out of the way **** turn the pulley around. The belt should go right on.
Let me know how you do.
thanks
Sep 07, 2009 | Garden
I need to know how to remove the shaft with pulleys on it that comes out the bottom of the engine
the shaft you are talking about is the crank shaft. in order to remove it you must first remove all pulleys, drain oil, then remove the case bolts. slide case off of shaft then remove the connecting rod bolts. crankshaft should come out hope this helps
Jul 09, 2009 | Briggs & Stratton Garden
Husqavarna engine pulley?
Do you have a manual for the tractor?
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
May 24, 2009 | Mtd Garden
I am trying to get the 11 hp Briggs & Stratton engine out of my Toro tractor to replace the gaskets, since it is using & throwing oil over abundantly. How do I get the drive & mower pulleys from under the...
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Mar 14, 2009 | Briggs & Stratton Garden
Toro Lawn Mower With Toro Power Tools Logo
51 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
