Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 139.18415 opens intermittently by itself why? Can I change the Channel?
    President:
  • 3,197 Answers
You can't change the channel but here are some things to look at.
Look at the LED light next to theSMART/LEARN button on rear of the motor unit. You may need to removea light lens cover in order to see it. If the light is flashingrapidly this means you have a stuck button on one of your remotecontrols. Take the batteries out of each remote control. When youremove the batteries from the bad remote, the light will stopflashing. This remote needs to be replaced.
If one of your neighbors remotecontrols is inadvertently programmed into your receiver, you doorwill open when their remote is activated. If this happens you willneed to clear out your receiver and reprogram your remote controls.Press and hold the smart/learn button for 6 seconds or until you seethe small LED light near the button turn itself off. If the abovesteps have been followed and the symptoms continue, there may be anelectronic short in either the wall control button or the receiverlogic board. In this case, remove the wall control wires fromterminals 1 and 2 on the motor unit. Should the symptoms persistafter the wires are removed, replace the receiver logic board. If thesymptoms stop with the wall control wires removed from the motorunit, replace the wall control button, and the wires leading to thewall control button.
Posted on Jun 07, 2010
Liftmaster garage door opens by itself intermittently
Check the codes on the sender and receiver. You did not post the model but something could be on the same channel
May 20, 2017 | Building Materials
My box is receiving the feed intermittantly. is there a common cold solder joint problem?
Hello this is Nick Franta with DISH.
During the intermittent signal loss/freezing are any error messages popping up on your screen? From the information provided the best solution would be to unplug the receiver from the outlet for 10 seconds. Also try to press the up and down buttons on the receiver itself when its freezing to see if it allows you to change the channel. If this doesn't resolve the issue we would need to send you a replacement receiver. Let us know if you need any further help!
Jan 18, 2011 | DISH Network 301 DTV Receiver
My liftmaster 3280 opens by itself occasionally. I have tested springs and they test fine.
Change the codes on the remote and of course the lifter itself, sounds as if some one in the neighborhood has programmed the same codes nearby.
Jan 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Whisper Drive Security + model HD900D that is opening by itself awhile after the door has fully closed & I've gone into the house, sometimes its hours after the door fully closes....
If the door hits the floor too hard the safety will reverse it to the open position. This can be an intermittent situation. A bad wall control or the wiring to it will also cause this problem. To eliminate them you can remove the wire from terminal #1 on the rear of the motor unit. A staple in the wire can cut through the insulation.
Jan 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Intermittent
Yes your receiver is bad and it is part of the logic board.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Apr 14, 2009 | Audio Players & Recorders
MY ROUTER KEEPS LOSING CONNECTION
Hello fieldon68, & to all the rest with the same problem.
There are many things that could be wrong, but intermittant discounnects sounds very much like a interverance from another wireless device. (ie phone, cell, etc)
To try to address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit ( unless you created a password, then enter that).
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou get disconnected wirelessly mainly due to an environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is one of the more popular reasons Belkin wireless connections can drop. Good Luck Mark P.S. Please leave a rating.
Jan 02, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
576 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
