Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Not moving on bottom of pool - Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
  • 640 Answers
These pool cleaners should have an easy to correct solution when it comes not moving properly. Ensure that the main drain and all suction lines are closed except the one that you are using. Check for debris in the flapper. Debris in the flaper can prevent movement and restrict flow.
Posted on Oct 28, 2010
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
Navigator pool cleaner just skims the bottom of the pool and does not sit on the bottom, it moves all around the pool but appears to be floating a little. How can we fix this so it will sit and move on the...
Interesting question. Do you have the special Lead Hose, the one with a colored cuff attached to the Navigator itself? Other causes can be, too little or too much hose, a pinhole leak in one of the hoses above water causing the hoses to float, not enough suction on the Navigator. You didn't say if you have the Navigator plugged into a skimmer or in a dedicated suction port in the wall. I would first try increasing the suction to the unit and see if your problem doesn't go away.
Sep 03, 2011 | Hayward Navigator Pool Cleaner
Cleaner will not go to bottom of pool
Have you adjusted the setting? If you have it set on "top" or "automatic", try moving your setting to strictly clean the bottom. If you have tried this and it is still not diving, I would suggest checking your pool cleaners hose floats. Make sure that they are spaced properly and that you do not have added hose weights.
May 20, 2010 | Hayward Phantom Pool Cleaner Complete with...
Krauly gets tangled in the hose constantly and will not untangle
With these pool cleaners, that is almost always going to be a problem with your hose balance. To determine if your balance is correct, turn off the pump and observe the cleaner. Hose balance is correct if the cleaner's seal rests flat on the pool floor and drive tubes make a 45 degree angle with the floor. If the hose rises toward the surface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose sags at less than a 45 degree angle, move the weights away from the Kreepy Krauly or separate the first two weights away from each other.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
sounds like the turbine or a-frame bearings are bad. A turbine kit with a-frames will be a solution. Also check the pod shoes for wear, should be a good 1/4" or better.
May 19, 2009 | Hayward Navigator Pool Cleaner
Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
251 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
