Question about Acer Aspire 6920 Notebook PC
I tried doing a live update to my Acer Arcade Deluxe 2.0 on my aspire 6920 and half way through it freeze up an now it won't work at all. What can i do to solve the problem ?
  • 749 Answers
Uninstall the acer arcade and reinstall it
Posted on Jun 06, 2010
I have a acer 5950G and it has acer arcade deluxe on it. it will not allow me to play my music. what do i need to run this program
first try updating the program:
  1. In the Arcade Deluxe program, click Advanced and, next, double-click Live Update.
  2. Click Yes to confirm and, then, Update Arcade to install the update.
normally that should fix the problem if not try to check your sound card as well as your speakers.
Jul 14, 2011 | Acer Computers & Internet
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
The Acer Arcade Deluxe Webcam is not working, but the Acer Crystal Eye Webcam is still working fine. Please, how can I solve the problem with Arcade Webcam software? I believe it stops working after some...
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
Oct 15, 2010 | Acer Aspire 55421462 Notebook
My Acer 6920G will not play Blue Ray DVD'S. I am unable to get helpful info from Acer. Tried to find a Driver to download with no sucess. Would greatly appreciate help
You also need a patch from Acer,
http://www.cyberlink.com/prog/oem/acer/update/index.jsp
Acer Arcade Deluxe v1.13.4806
Go to acer arcade deluxe
select "Play Movie"
Select "settings"
select "BD settings"
Select "region code"
Select "region B" for the UK
Important Note!:
You can only change your region !!! 5 !!!! times!
that is 5 times!
I am totally stressing this.....5 times!
You may have to do this a second time so your computer locks on to this region code.
If you watch an american blu-ray vid, on the fifth change of the region code your computer locks to this region !FOREVER!
SO I AM TOLD.
Feb 26, 2010 | Acer Aspire 6920 Notebook PC
Can not play cd's or dvd's
There is no need to use acer arcade, you can just use windows media player or windows media center (which is acer arcade just changed a little by acer). The only way to recover acer arcade would only be possible by using your acer program recovery disks.
Feb 09, 2010 | Acer Aspire 6920 Notebook PC
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
When I try to launch a Blu-Ray movie Acer Arcade Deluxe attempts to connect to what I guess is a non-existant web site which it fails to do. This is the end of your movie playing experience. There is no...
Ok I,m not sure i can solve the problem for you, but have had problems with my acer 6920 G. Hopefully this will help. I was playing blu ray discs on my acer 6920 G wich i believe has the same sony/nec Optiarc blu-ray player. It was playing blu rays fine for a while. then as newer and newer releases were coming out it would not play some blue rays from certain manufacturers (Fox). Then newer releases from other manufacturers would not play. I was getting updates from acer arcade deluxe that would allow me to play some of the newer releases. The only problem i was having was that the updates (patches?) were not keeping up to the newer releases. The last update from acer was corrupted or somthing was wrong with it and then my blu-ray player wouldn't play anything at all. To solve the problem I reinstalled acer arcade deluxe using the acer e recovery management. This fixed the problem. But now back to square 1. My older blue rays will play but not the newer ones. I've been going over this problem for a while now. The Acer site was no help at all. The e-mailed me some solutions both hardware and software but weren't even close to what the problem is. You can try Cyberlink Power DVD 8 and it runs better than the Acer Arcade Deluxe. (They write the updates for the acer arcade deluxe) It is expensive the last time i checked. Hope this helps a little.
May 01, 2009 | Computers & Internet
Acer Aspire 6920 Notebook PC Logo
172 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
