Question about Kenmore 22422 Top Load Washer
Do water level is not working. It will over flow
The water level is not working. It doesn't stop the water flow when it reaches the water level we have it on. Therefore, it overflows.
  • 54 Answers
Change your pessure switch. Thats the switch that says
medium low or high loads
Posted on Jun 06, 2010
Whirlpool washer AWG 305, water doesn't stop.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 24, 2013 | Whirlpool Washing Machines
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Bosch Aquatak Clic 125 running problems - keeps pulsing and unable to reach continuous full pressure - has been working well up to now - water pressure OK
After the machine has stared the wash cycle stop the machine. Check the water level in the sump. It it is below the required fill, the pump will drain the sump, suck air resulting in pulsing.
Add a modest amount of water about a quart or so and try continuing the wash. see if it reduces the pulsing. Continue to add to determine if it is the water level.
If you confirm that the water level is low, depending on the model it usually fills on a timer. If it had been working properly then either the stop valve under the sink has allowed the internal rubber washer to dislodge into the flow path, or the inline filter at the connection to the dishwasher is clogged or the electric solenoid at the washer is failing and not allowing the water to enter at the prescribed amount.
Hope this helps?
Below the stop valve do to the hot water is known to have the rubber seal fail which can plug the hose limiting the water flow. The valve can be repaired without removing it. The stem with the house water off can be removed and a new rubber seal installed. remember to remove the debris from the failed seal.
12215403-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg The screen can clog in the image below restricting the water flow. Disassemble and clean.
Mar 29, 2012 | Dishwashers
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
My sunfire overheats and leaks out overflow everytime i drivee it.i changed water pump,thermostat the fan is working fine and had a water pressure test done last mth
DID YOU BLEED AIR OUT THE COOLANT SYSTEM.TO BLEED COOLANT SYSTEM, FILL THE COOLANT SYSTEM THROUGH THE RESERVOIR TANK OR THE RADIATOR UNTIL THE FULL COLD MARK IS REACHED.BESURE TO USE 50/50 HALF WATER AND ANTIFREEZE.YOU CAN BUY ANTIFREEZE THAT IS ALREADY PREMIX 50/50.AFTER ADDING ANTIFREEZE TO RESERVOIR OR RADIATOR FILL RADIATOR TO FULL MARK OR IF YOU DONT HAVE RADIATOR CAP ON RADIATOR POUR ANTIFREEZE IN THE OVERFLOW JUG UNTIL COOLANT LEVEL STAY THE FULL COLD MARK.WAIT AWHILE UNTIL COOLANT LEVEL STOP DROPPING.NOW INSTALL THE RADIATOR OR OVER FLOW JUG CAP.START THE ENGINE AND ALLOW IT TO RUN UNTIL NORMAL OPERATING TEMPERATURE IS REACHED AND THE UPPER RADIATOR HOSE BECOME HOT.STOP THE ENGINE AND OBSERVE THE COOLANT LEVEL IN THE OVERFLOW JUG. THE COOLANT LEVEL SHOULD BE AT THE FULL HOT LINE.ALLOW THE ENGINE TO COOL UNTIL THE AMBIENT TEMPERATURE IS REACHED THEN CHECK THE COOLANT LEVEL IT SHOULD BE AT OR ABOVE THE FULL COLD LINE.ADD MORE COOLANT IF NECESSARY. WARNING BECAREFUL WHEN OPEN THE RADIATOR CAP OR JUG OVER FLOW CAP.USE A LARGE RAG OVER THE RADIATOR CAP TO KEEP FROM GETTING SCALDED.OPEN RADIATOR CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDED.WAIT UNTIL ENGINE COOL DOWN BEFORE OPENING RADIATOR CAP OR OVERFLOW JUG CAP.WEAR SAFETY GLASSES.
Jul 12, 2011 | Pontiac Sunfire Cars & Trucks
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
Flood!
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 07, 2009 | Washing Machines
Kenmore 22422 Top Load Washer Logo
108 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
