Question about Goldstar WG5000 Air Conditioner
I plugged up my wg5005 after a year in closet and it makes noise but the fan doesn't blow any air out..It runs but fan blades aren't spinning
    Novelist:
    Champion:
  • 246 Answers
You said 'it runs but fan blades aren't spinning.'
Taking this "literally" - what it means is that the fan blade is 'loose' on the shaft of the motor. Look at the fan blade, the hub - in particular - and you will see where a 'set screw' should be.
If it's still there and 'loose,' all you have to do is 'tighten the screw' on the shaft of the motor (on the flat side).
If the screw is missing - you just need to find a screw that will fit the hole and replace it.
All of the above being said - it's also possible that you are hearing the compressor run and thinking the fan motor is running when in reality it's not. In the case that the fan motor is actually "not" running - then you have a completely different problem - the most likely problem being the fan motor is defective - in which case you will be out around $150 and up to replace it.
With the cost of window units today being fairly reasonable - you will probably be better off looking for a new unit.
Still, on the chance you have a simple problem, i.e. a burnt wire, or bad capacitor - it might be worth it to have a Service Tech take a look.
Hope this helps.
hope this helps
Posted on Jun 12, 2010
Blower making noise and not blowing air
The fan blades broke free from the motor so the motor is spinning but the blades not spinning
Feb 08, 2017 | Cars & Trucks
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Fan noise ecoquest 2.1
sounds like the bearings are going bad on the motor check and make sure the fan blades aren't rubbing anything at higher speeds sometime's they will flex
Jul 04, 2012 | Ecoquest Fresh Air Air Purifier
My fridge is making a lot of noise. It does not stop. What might the problem be? Model# 2539668010 Serial# BA62202425
This is a basic no frills refrigerator so that things that can make a lot of noise is limited. And where you say it doesn't stop, then it is most likely a fan. You have two one in the freezer compartment that could have accumulated some ice on the blades which could through it out of alignment. So it might be hitting the sides of the case.
The other fan is underneath your cabinet, and blows air across the compressor, and condenser coil. If there is a lot of lint or debie in this area then the fan blades could be come coated and then the out of balance condition could cause noise.
If a cleaning doesn't fix the problem then you will probably have to replace the fan blades and motor.
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
Kenmore 8000 BTU A/C runs, but won't blow air
Sounds like a problem with the fan. There maybe something caught in it. If you had it stored is an outdoor environment then some wildlife (rodents) may have nested in it. You need to remove the cover and do a visual inspection. If nothing is caught in the fan then try turning it by hand and see if it spins freely. Some units have just 1 motor that turns the evaporator and condenser fan blades; others have 2 seperate fan motors.
Jul 07, 2010 | Kenmore 75051 Wall/Window Air Conditioner
WG5005 - plug in outlet, won't come on
You have a direct short.Run the unit on fan only ,does it trip?if not you might have a shorted compressor,possible 5 year warranty.If still trips possible tsat or control board depending on make/model warranty status
Jun 20, 2009 | Heating & Cooling
Air conditioner is frozen on the inside
I would shut it off...most A/C's never need to defrost...but I'm not 100% sure about some of the newer models....In my 35 years experience.I have never seen a defrost on anything but a freezer/refrigerator....a humming noise indicates a motor is frozen up...usually a fan motor..in your case it will be the evaporator/condenser fan motor...(your type has a double shaft..that has a fan blade for the evaporator and then another shaft upon which the condenser fan blade is attached...if this goes out it will hum...and it will definitely ice over....and these window units are never supposed to ice over...except when air is not blowing over the evaporator ..or air is not blowing over the condenser. Yes it will continue especially if the fan motor is going bad...and yes keep power to it off..or the compressor can burn out and that IS THE AIR CONDITIONER...if you lose that you may as well buy a new one as the cost of repairs will be more than a new unit.....usually....If you are lucky you can take the cover off an spin the fan blade by hand and try to start it while the blade is spinning to see if it was just stuck...but it may not restart after it stops...if it doesn't you will need a new fan motor. Also next time include the Make and Model #. thanks and good luck...than you for rating my effort...the Fang.
Apr 08, 2009 | LG Electronic Window Air Conditioner
Loud Fan Noise
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Apr 23, 2008 | E-Machines eMachines Desktop PC
Goldstar WG5000 Air Conditioner Logo
216 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
