Question about Roper REX4634KQ Electric Dryer
Dryer AD55 barrel not rotating.
Engine humming but barrel not rotating. Bands / pulleys are all ok. New engine?
  • 1 more comment
  • bshepherd Sep 30, 2008
    belt broke around barrell, dryer hums when start button is pushed. is a new belt all i need?
  • Anonymous Nov 14, 2008
    Drum will not turn, If I turn the drum by hand while door switch is depressed, the heating element will energize, and I hear what i think is the exhaust fan come on.
  • bshepherd May 11, 2010
    Dyer belt broke around barrel, humms when start button is pushed but nothing happens. What do I do to repair?
    Genius:
  • 1,073 Answers
Belt off of motor pulley or the belt is broken
Posted on Apr 10, 2008
Why does Drum does not rotate
can be severl causes check drum rotates by hand freely is good most common fault is the capacity needs replacing
Jun 08, 2014 | Fisher and Paykel Dryers
Asko T701 stopped running.
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Sep 13, 2008 | Asko T701 Electric Dryer
How do I replace the main bearing in an AD55 Fisher & Paykel dryer? How difficult is it to get at?
not that hard you take the back of then take the barrel out punch out the 56833 strem grease bearing then replace with new one and re assemble just note the way the driver belt comes of there tricky to put back on
let me know how you went
Dec 31, 2010 | Fisher and Paykel Dryers
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
WHY DOESN'T MY DRYER TUMBLE
Hi, If your dryer doesn't tumble,The problem might be from three different reasons,which are described below,check these:
1.BELT; Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
2.MOTOR; If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt.Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
3.DOOR SWITCH; Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks and good luck
Jun 21, 2010 | Dryers
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
THE DRYER WILL HEAT BUT THE DRUM WILL NOT TURN. I HAVE CHECKED THE BELT AND IT IS OK. NOW WHAT
Hello. I can help you. Since the belt is ok there are only two other possible problems:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Jul 16, 2009 | Dryers
The dryer drum won't rotate and the belt is okay.
motor sorry
do you hear any hum or hesitation when it actually does turn on and rotates if yes you need a new motor
Jun 06, 2009 | Dryers
Maytag drum
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Roper REX4634KQ Electric Dryer Logo
260 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
