Question about Microwave Ovens
Durabrand toaster oven TO-88 top bulb needs replacing
My Durabrand toaster oven model TO-88 top heat lamp doesn't work any more. It just toast from the bottom. Obviously the top ''bulb'' will need to be replaced. Please advise on how to get this done. The Instruction manual doesn't provide service information.
  • 95 Answers
SOURCE: Replacing the lamp in the microwave of a Kitchenaid KEMC378KSS01
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
I hope this help
What About Bob
Posted on Feb 11, 2008
  • 185 Answers
SOURCE: INSTRUCTION BOOKLET
look it up on the internet try that
Posted on Mar 26, 2008
rickzilla
  • 706 Answers
SOURCE: GE Spacemaker Model No. JVM1650AB 003
Hello Diana,
Here is a link to the GE User manual for your microwave oven.. Once you download it.. You will find a section on light bulb replacement that details how to install and which particular bulbs to use..Hope this helps you..
http://genet.geappliances.com/DocSearch/pdf/49400821.PDF
Good Luck !
Posted on Sep 14, 2008
SOURCE: I need operator/ instruction manual
WELBILT APPLIANCE CORP.OF AMERICA P.O. BOX 220709 GREAT NECK, NEW YORK 11021 Write to this address and they should send you a manual for your toaster oven, here is a phone # also1-800-872-1656 Hope this gets to you Heather_s514 From smoothygirl63@yahoo.com
Posted on Dec 11, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: Need new lamps for Sharp
The original part number was RLMPS0001YBE0 but it is listed as no longer available.
If the bulb unscrews from its socket, then you should be able to remove it and take it for a generic replacement at a home improvement center (like Lowes) or the light bulb section of Wal-Mart.
If its is one-piece unit with bulb and socket that are inseparable, then you'll need to sub that with a similar type assembly at a local appliance parts company. You can see the Yellow Pages or yp.com to find those.
Posted on Dec 22, 2010
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Samsung Bio Ceramic Microwave lamp fused.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
You can order specific Samsung parts here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 03, 2008 | Samsung MW1030WA Microwave Oven
I needed toaster oven assistance. My year and half year old toaster oven's timing knob has broken. The model number is TOV200. I wondered if Toast Master could let me know how much would cost to send me a...
You may contact consumer_relations@toastmaster.com.
If they refer you to Salton, you should try to get a phone number, because their Web site was not working when i just tried it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | Microwave Ovens
Replacement bulbs still do not work
Most electronic control boards have undersized circuit wires that can't handle a catastrophic lamp failure. The circuit trace will open like a fuse. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for open circuit trace.
4. Repair circuit trace...lights work again....
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
INSTRUCTION BOOKLET
Mar 25, 2008 | Microwave Ovens
Microwave Ovens Logo
130 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
