Question about Microwave Ovens
I have a sanyo Microwave model EM-S625S and currently have a problem. After a few minutes of switching it on it beeps and then the clock disappears and the 1s light is lit. The lights then alternate between 1s and 2s. Once this happens I cannot use the microwave. If I switch the microwave off and then on, I can use the microwave. It is annoying to do this all the time.
  • j255 Jul 14, 2008
    I have the same problem with the same microwave and am unable to use it when the 1s comes up. There is no reference to symbols in the manufacturers book to help either.
  • simonbb Jul 21, 2008
    Me too, I also have the Sanyo EM-S6252 - The same problem happened last week..... I have tried leaving it unplugged but it just goes back to 1S - No clock, no other functions work, and the thing is useless!!!! No solution in the book. :(
MicrowaveSvc
  • 9098 Answers
SOURCE: How to changee clock on
You can find several models of Sanyo microwave manuals here. Even though yours may not be there, there might be one close enough to help you here.
You can locate Sanyo manuals, part distributors and authorized servicers here.
You can find Sanyo UK microwave owner's manuals here.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: lamp replacement in a sanyo microwave EM-D9553
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: lost manual and dont know how to set clock
download new manual from the net.
Posted on Jul 08, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a sanyo EM-S625S microwave and it won't
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a shorted membrane keypad.
here.
Posted on Dec 13, 2009
MNfisherman
  • 11896 Answers
SOURCE: We have a Sanyo microwave
Press Clear, Then Press Clock, Then change hour and minutes, press clock again.
Posted on Dec 31, 2010
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
I have a sanyo EM-S625S microwave and it won't stop beeping and won't allow me to use any buttons can you please help?
here.
Dec 11, 2009 | Sanyo Microwave Microwave Oven
Setting clock on EM-G2567S
1. If you press the 'Delay Start' button, the time display will go blank.
2. Now enter the correct time, using the 'Minutes' buttons to set the hour, and the 'Seconds' buttons to set the minute.
3. Now press 'Clock'
4. Sorted!
Nov 25, 2009 | Sanyo Microwave Ovens
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to changee clock on a Sanyo EM G4775 Microwave ?
Nov 01, 2008 | Sanyo Microwave Ovens
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from http://www.vancebaldwin.com If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Nov 20, 2006 | Sanyo EM-P790 Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
