Question about Vizio VP322 32 in. Plasma TV
Visio plasma tv vertical white stripe
Vertical white stripe approx 1 inch wide in center of screen.
  • 103 Answers
SOURCE: blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Posted on Mar 03, 2008
  • 5 Answers
SOURCE: 2" vert. red stripe
I have worked on many Vizio televisions under warranty and what you are descriping is often a result of the X boards going bad. If the telelvision is under warranty, contact Vizio at 1-877-MYVIZIO, if it's no longer under warranty, the cost of repair is probably going to be more than the cost of a new tv unfortunatly. I always recommend buying the extended warranty's with these televisions.
Posted on Oct 20, 2008
DRACO A5OG
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
  • 1779 Answers
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Posted on Feb 18, 2009
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue vertical stripe
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vizio VP322 32 in. Plasma TV Logo
152 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
