Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Regarding HDD partition
How to create recovery partition in any laptop or desktop hdd. (like ibm one touch recovery)
    Novelist:
    Champion:
  • 236 Answers
Such autorecovery are provided by manufacturers. what brand of laptop are you using?
Posted on Apr 10, 2008
The HDD of my Acer Aspire 5102WLMi got broken. I bought a new one, partitoned it, load the D: drive with Acer stuff from backup, mounted it in the laptop and started this with the recovery CD. This...
@hellepie
The HDD interface on this machine is a PATA so BIOS shows the correct interface as IDE 0. Upon loading up the recovery disc (I'm assuming it's a good condition genuine Acer recovery media), what it does is that it re-images the HDD to the default file system and automatically occupies the full partition of the HDD so if you have already re-partition it, the problem might lie right there. Try to do the following:
1. Erase all partition on the new HDD that you have purchased and format it with NTFS and try to load the Acer recovery discs again.
2. If that won't work, try to use a retail copy of Windows and check if it fully install Windows. If it does, try to create a duplicate copy of your Acer recovery discs, it might just be faulty and try again.
Good Luck.
Sep 04, 2011 | Acer Computers & Internet
Laptop is not getting booted
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
Apr 01, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
I formated completelly hdd (acer 7720g) i want to to recreate pqservise in order to have d2d recovery(recovery management).i have the dvd recovery of factory settings but the dvds didnt manage to create...
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
May 23, 2009 | Acer Aspire 7720-6155 Notebook PC
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
FAT32 to NTFS results in HDD failure
Your partition is now corrupt which may or may not be related to your hard drive being physically bad (though most like is a bad drive). You can MAYBE retrieve data from it if you take it to a data recovery specialist or get the proper hardware to hook the drive up to a working desktop/laptop and obtain data recovery software like Ontrack Data Recovery.
Nov 08, 2008 | Computers & Internet
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
System recovery
Hi
Please go into my conputer and check whether u have a recovery partition or not..... If you have... restart your system and tap on F11..... go to recovery partition... U'l get a pop up to create recovery cd's.... Plz create the cd's once u get the pop up
Oct 22, 2007 | Computers & Internet
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
Jan 31, 2007 | IBM ThinkPad T30 2366 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
51 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
