Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Dishwasher stopped cleaning but appears to run through cycles. Possibly water starved. The bottom "sprayer has some water coming through the holes but is not spinning, (although spins freely by hand). The top and middle "sprayers" definately aren't functioning. Stopped working suddenly, (not a gradual change).
  • kslovic Jun 06, 2010
    Your assistance was very helpful. Thank you for all your help. Saved an expensive service call that was relatively easy to fix with your assistance.
  • 6,784 Answers
HI. I agree with your assessment. There may be some sort of blockage within the hose assembly. I recommend to inspect all hoses that correspond to the actual recirculation pump. Check the drain hoses as well.
The recirculation hose can be responsible for problems with poor rinsing of dishes and washing as well. Minor clogs will obstruct the water flow, thus, preventing for an optimal cycle. This issue will cause a low water pressure state, which in return, will hinder the rotation of the sprayer arms. To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well for obstructions.
When checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it. Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full strength). Disconnect the recirculation hose and check it the same way. Once you have cleared or verified that there are no obstruction within the affected areas, simply reconnect all the components and power up the unit for a test run.
During the test run, if you experience the same issues with low water pressure to the sprayers, move on to the water inlet assembly. The only other culprit, besides a clogged recirculation assembly, will be a failing inlet valve assembly. This assembly may be having difficulties with keeping the solenoid controlled valve fully open. This will restrict the normal water flow, thus, creating the issues you are experiencing as well. Use my quick testing procedure below to confirm proper function at the valve assembly.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
Posted on Jun 06, 2010
  • 7 more comments
    Thanks. While waiting for a response, I continued research. Do you think a plugged sump could possibly be the culprit? This looks like it might be a little easier to tackle first.
  • Michael Masters
    Michael Masters Jun 06, 2010
    A plugged sump port may be an issue, but these sections of the actual sump shouldn't hold the plugs to long. Most clogs tend to free themselves overtime in this area. I do agree that it is worth checking. It is a great starting point..
    Ok. I accessed the sump pump. The screen was approx. 75% clogged and the chopper blade is broken off. 2 questions...
    Can I run the dishwasher with the screen and chopper blade removed, (and make sure we rinse the dishes before running the dishwasher.
    Where can I get a replacement shaft, screen and chopper?
  • Michael Masters
    Ok, i will need the entire model number, if possible. This will insure that i can provide the proper replacement parts and part numbers. You can purchase all parts from the sears parts direct website, if you wish.
    Concerning the units operational value without the sump fine particle screen and chopper mechanism:
    It is possible to run the unit without these components, but i strongly do not recommend it. The screen and chopper are very important devices that heel most obstructive material. I would advise against this, even though it is possible.
    Sears parts direct site
    The Repair clinic
    The model number is KUDl01lBS3 Serial number FR0203677. It the plastic shaft that is actually broken. However the chopper was also partially mangled. Does it come all as one assembly replacement part...shaft/spring/washers/screen/chopper?
    I'm running it now to see if it it fixed the upper water flow issue. It looks like it is working but I'll wait until the cleaning cycle ends to be sure. If not, I'll start attacking the hoses.
  • Michael Masters
    Ok, the actual chopper will be shipped as an assembly. The part number will be 8268383.
  • Michael Masters
    The part number for your new screen will be 8268391
    Thanks for the PN's. Does the metal washers that slide down the rectangular portion of the shaft go on either side of the screen? They were not attached to the shaft when I found them.
  • Michael Masters
    Either side will be suitable concerning the washers..
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
Hi ,my hotpoint aquarius dishwasher FDW60 is not cleaning properly.It seems to be completing a full cycle but the tablet has not dissolved fully.or the dishes are all dirty.Can you advise please ,Dermot
If you have hard water, it is likely that the sprayer in the bottom of the dishwasher has become clogged with hard water deposits. This may be the case, even with soft water.
On most models, the sprayer looks like a propellor, and can be removed by carefully unscrewing the fastener at the top and carefully removing the sprayer. If you have a digital camera, I recommend taking pictures at each disassembly step, so you know how to put things back together (in the reverse order that they were removed). It should not be too difficult to remove it, but you may have to gently work with the fastener at the top to get it to budge.
You will need to clean all the spray holes and ensure that none are clogged. I used an ice pick and toothpicks to clean out the holes recently on my dishwasher. (We have hard water).
You may need to soak the sprayer in vinegar overnight if you're not able to completely clean out all the holes.
Mar 30, 2011 | Dishwashers
Dishes not getting clean. Long cycles.
half a jug of CLR in the bottom of the machine on a full wash cylce will do wonders. Set it to the longest and hotest setting. let it run until the bottom fills and let it set for about 30 mins to an hour....The longer the better you chances of getting it right on the first try. Keep stopping your machine for each fill and let it cycle through.
run atleast one more cycle before you put dishes in their.
HOT WATER CARRIES MORE MINERALS THAN COLD WATER!!!!!!!!
Naturally, hot water dissolves more minerals than cold water. This allows for a larger change of mineral build up at junctions, especially those exposed to air. Try a toothpick in the holes on the sprayer, just be careful not to push it all back in and create a blockage
GOOD LUCK AND PLS RATE THIS POST!!!!!
Dec 01, 2010 | KitchenAid 24 in. KUDI02CRBS stainless...
My dishes are not coming clean, grit and particles are stick to the bottom of the glasses when cycle is finished. Would this be a filter problem?
My wife had the same problem which was fixed by changing detergent and appeared to be caused by hard water. Make sure the screen/filter in the bottom area is clean. It may help to run an empty cycle with detergent and white vinegar to remove hard water deposits from the screen/filter. Hope this helps!
Oct 02, 2010 | Estate TUD6710 Built-in Dishwasher
Dirty dishes coming out of dishwasher dirty
check your drain line it should go up from bottom of d/w and then go down to drain that is so water from sink wont back up into d/w
Oct 27, 2009 | Dishwashers
Dishes don't get clean
Remove the bottom screen assembly and look for debris, like pieces of plastic film and grease, that are blocking water access to the pump impeller intake. Sounds like flow is low and that means to look at the pump intake.
Sep 26, 2009 | Whirlpool Dishwashers
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher
dishwashers need alot of water ..check hoses for blockage and water pressure...should be around 40. also check and see if proper drainage. water has to get to the top by hoses to a sprayer check that...a motor has to run the sprayer,that looks like a 2 blades whirling about with holes, and might have clutches and gears worn in that cycle...you will stand there and hear all the cycles and can open it to see if top gets water. good luck
Aug 31, 2007 | KitchenAid 24 in. KUDI01FL - Multiple...
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
122 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
