Question about Princeton Digital VL1918 Monitor
Blinking Monitor My monitor has started blinking power is cycling on/off. Any ideas?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 06, 2010
Testimonial: "Awesome solution!"
  • aalex07 Dec 09, 2010
    Very Good Info Thanks
    Repair kit for the Monitor
    http://lcdalternatives.auctivacommerce.c...
I found a Repair kit for this Monitor
Posted on Dec 09, 2010
After a few minutes my monitor starts blinking
this is power issue please check in alternate power socket else check power cable
Feb 11, 2014 | Samsung 923NW 19" LCD Monitor
Monitor don't start with start of PC.
Replace the electrolytic capacitors on the power supply board.
Some will have bulged, but it'll be a good idea to replace all of them
May 15, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Blinking Power Light and monitor will not come back on....
The monitor needs an internal eletronic repair. Do you have the the necessary anti static tools including soldering iron. If so I can help you with the repair, else take it to a pro.
Apr 27, 2009 | X2Gen MG19MY 19" LCD Monitor
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Princeton Digital VL1918 Monitor Logo
790 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
