Question about Nokia 3110 Cellular Phone
I need a master code that can break Nokia 3110 security code which I have forgotten.
dboss
  • 28 Answers
SOURCE: Nokia Security
Master code & IMEI no. has nothing to do with unlocking the security lock of your phone, you need to have a unlocker/flasher
hardware and software to do it or visit your friendly service shop.
Posted on Mar 26, 2008
abhi2664
  • 3 Answers
SOURCE: master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Posted on Jun 10, 2008
SOURCE: forgot the security code
i forgot my security code
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: Need master security code
Try to reset factory settings using UFSx or Jaf device..then it would be back to 12345 your default security code.
Posted on Jun 02, 2009
mikegbali
  • 324 Answers
SOURCE: forgotten security code for 5220
Hello, enter 0000363035... that is your master code, use that in place of your security code
Posted on Sep 27, 2009
I have forgotten my security code for nokia 3110c and my imei no. is 359728/00/433397/0
So go 2 google and type "get master code for nokia mobile" after you get the master code using your IMEI no. In the password place type master code it may work
Jan 09, 2013 | Nokia 3110 Cellular Phone
I forgotten my security code. so i want security code for 1200 IMEI no. 356816/02/328041/4
If you forget the code means you can master reset it using the master reset code ,You can get the master reset code from here
Unlocking4free.com and reset from security Lock. You can get the code for DCT Nokia There.
Oct 11, 2011 | Nokia 1100 1101 1108 1110 1112 1200 1208...
I have forgotten my security code how can i unlock it
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Onlinegsmunlock.com , it has the best services for the master reset code for your Nokia 3110 model mobile.....I hope that it may helpful to you....
Aug 17, 2011 | Nokia 3110 Cellular Phone
I've lost my imei and i've forgotten my security code dont know what should i do?
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Onlinegsmunlock.com, it has the best services for the master reset code for your Nokia 3110 model mobile.....I hope that it may helpful to you....
Aug 03, 2011 | Nokia 3110 Cellular Phone
I've seem to have forgotten my phone's security code. I'm using nokia 1608
Security code lost means, you get the master reset code for that one.......
you can get the master reset code for your Nokia model mobile, through this site http://www.theunlockspot.com/nokia-dct-master-code-service/rs10wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
Nov 11, 2010 | Nokia 3110 Cellular Phone
Security problem
Nokia phones do not have a master override. Once forgotten the phone will need to be replaced. You can also try the default code which is 12345.
Sep 12, 2009 | Nokia 3110 Cellular Phone
3110c problem
So you don't know or you have forgotten your Nokia Security code? Don't worry the solution lies in this very page! No data cable needed with this new solution. All you need is a Master Code! Forgetting your security code can be frustrating. For example You need this code when you want to reset your phone settings.
So What is a Master Code I Hear you Ask? Well, lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
How do you Generate the Master Code? The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Simply enter your 15 digit serial / IMEI number into my online tool (see link below). Your master code will then be calculated instantly.
Which Nokia Models will this work for? The calculated master code will only work for DCT3 and DCT4 Nokia phones. It will not work with the newer BB5 handsets. See below for a rough guide or look at my Nokia generation list to check if your model is supported. The feedback I have received is that's IT WILL NOT WORK FOR THE 6230i model (the 6230 is fine).
Compatible phone models
  • DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
  • DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible models
  • BB5 5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280, 6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288, N70, N71, N72, N73, N80, N91, N93, N70 Music Edition, N95, N91 8GB, 6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110 Navigator, E65, E61i, N80 Internet Edition, 5700, 5070, 6120 Classic, 1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic, 6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism, 6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800 Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism etc.
  • ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
I plan to write a security code tutorial for BB5 handsets shortly (sadly the solution for these handsets is not as simple)
Please Note:
The default security code for ALL Nokia handsets is 12345
This is sometimes called the phone lock code.
Feb 27, 2009 | Nokia 3110 Cellular Phone
Security code
how to break the security code of nokia 3110
Apr 23, 2008 | Nokia 6230
Nokia 3110 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
