Question about Garmin StreetPilot c340 GPS Receiver
GPS looses direction in city streets
When I drive through the city the system acts erratically
  • 504 Answers
If you are driving in a city with a lot of tall buildings, trees or elevated trains, the unit will lose the signal from the satellites. This is due to the GPS receiver used on the C340. It may help to place the unit in WAAS (Wide Area Augmentation System) mode. This uses ground information as well as satellites to help you navigate. Good luck.
Posted on Apr 15, 2008
2007 Mahindra Scorpio has an erratic rev counter and battery light
check the condition and tension of the drive belt. Check that the battery terminals and posts are shiny clean and tight. Have the battery load tested for faulty cells. Have the alternator tested for output
Apr 04, 2014 | 2007 Mahindra Scorpio 2.6TD
The SERVICE BRAKE SYSTEM light comes on when driving and stays on
i had a customer with a 2004 gmc sierra 2500hd 2wd that stated that the srevice brake system light came on while driving. the transmission would shift hard and erratic plus the speedometer was erratic. the check engine light came on with two codes p0502 and p0503(vehicle speed sensor A low input and vehicle speed sensor A intermittent/erratic. i replaced both vehicle speed sensors mounted on the driver's side of the transmission. both of the speed sensors were the same. test drove the truck after and all issue were solved.
Feb 22, 2010 | 2003 GMC Yukon Denali
What is the proper way of using overdrive,how and when you have to use it?
If you are not climbing steep hills or towing, leave it on all the time. Turn it off for low speed/high strain driving like towing, climbing and off-roading.
i hope this helps
-matthew
Oct 25, 2009 | 2001 Mitsubishi Montero
Eratic platter direction and speed changes.
Have you seen this solution (Padster07's), it solved my problem: http://www.fixya.com/support/t477894-vestax_pdx200_platter_keeps_changing
Oct 06, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Erratic/non functioning speedometer
replace the battery, you can drive the car to a part store and have them test it first(they usually won't charge you)
Aug 16, 2009 | 1991 Volvo 740
Cummins Diesel Truck Erratic Speedometer and Shifting
Although you didn't mention it, the speedometer probably bounces also. Replacing the speed sensor on the side of the transmission should solve both your problems. Good luck
Apr 10, 2009 | 1996 Dodge Ram
Erratic shifting on 2001 f150 pickup
How many miles on it? Do you mean overdrive? Over drive will clunk when shifting in cruise. Mine lasted 212,000 miles but I have heard of them going out after 120,000, depends how you drive. That Traney is good till it starts acting up then you will need a complete overhaul. I got it done for $1800. Do not go to a Ford dealer, they quoted me $3200.
Jeepgreg
Dec 19, 2008 | 2001 Ford F150 Styleside SuperCrew
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
