Question about Toshiba TEC B-882 Thermal Label Printer
I get an 'open-head' message. All sensors seem to be in the right place
    Champion:
  • 254 Answers
There is a micro switch at the back which is responsible for this error.
Either you strap it or place the lever at the top position
Posted on Aug 24, 2011
HP Officejet Pro 6830 - "The print carriage cannot move"
Unplug the printer and wait 20 minutes and then re-plug.
Jun 20, 2017 | HP Office Equipment & Supplies
Epson Stylus Photo P50 - flashing alternate amber lights on ink and paper buttons... please advise of error
This is an identical issue to the one reported here:
http://www.fixya.com/support/t13406382-epson_p50_not_respond_blinking_lights
As per the information provided in my solution you can either get the printer serviced or fit an external waste kit and reset the waste counter yourself.
Jul 14, 2011 | Epson Office Equipment & Supplies
How can i reset de saeco odea giro plus ? I can not place the central unit because the axes or spindle is not in the right position.
Turn off the machine. Open the side panel, remove the dreg tray, remove the dreg box and remove the brew group. reinsert the dreg box without the tray. Using a flat head screw driver insert lightly into the slot where the brew group sensor is until you hear a click. Hold the screw driver in place while closing the side door and turning it on. The head will re-align. Now open the side panel, remove the box and reassemble. Leave the machine off for an hour and turn back on. That should reset it.
Jan 10, 2010 | Saeco Odea Giro Plus Coffee Maker
Hyundai Excel 97 will not start, cranks well.
I finally traced my similar problem to a broken wire into the plug going to the crank angle sensor which on this animal is located at the front of the motor on the right hand side when looking at the motor from the front. It is just below the clutch slave cylinder and is held in place by a 10mm headed bolt or phillips head (posi drive) bolt.
Good place to start.
franknpeg
Apr 18, 2009 | Hyundai Excel Cars & Trucks
Zebra 220xiIII Error Condition Head Open will not go away
The head open sensor is inside the printer is detected by the gear head.
Mar 16, 2009 | Zebra 220XiIII Label Printer
Brother MFC-215c Continuous Paper Jams (Bad/Dirty Paper Sensor)
Open the printhead cover carefully. You have to pull up the mini circiut board inside. Here you can clean the sensor.
Nov 25, 2007 | Brother Multi-Function Center® MFC-215C...
Epson Stylus CX6400 not printing
The head assembly is attached to a photo sensor that tells the printer when it is at the ends of its travel.
Sounds like this mechanism is not working properly.
Check to make sure thare is no obstructions or dirt in the paths at the ends of the print head travel.
You can use an air gun to clean the printer (JUST KEEP IT AWAY FROM THE PRINTER CARTRIDGES) as the ink will FLY EVERYWHERE.....
Oct 29, 2007 | Epson Stylus CX6400 All-In-One InkJet...
Brother mfc 5460 cn Paper jam problem
Hi, this document should help you clear the paper jam error. http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000005674&Sympt=How+do+I+clear+the+message+Paper+Jam+from+the+display%3f+printer+jam&Model=991&ProductGroup=5&Keyword=paper%20jam Good Luck
Sep 15, 2007 | Brother MFC-5440CN All-In-One InkJet...
Get troubleshooting message
The encoderstrip which gives the head the position is out of place. You have to open the printer (cable, cover, screws..) and to put the encoder strip into the right place on top of the printhead. The encoderstrip is the foil which runs paralell to the drivebelt of printhead.
Sep 03, 2007 | Brother MFC 240C All-In-One InkJet Printer
Toshiba TEC B-882 Thermal Label Printer Logo
106 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
matt
matt
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
