Question about Zanussi FLA1101W Front Load Washer
Does not empty the water and does not rinse or spin
I have checked the blockage on the front and the rear of the machine and there is no blockage.the drum turns and performs rest of functions.
the machine model is
FLA 1001 W. I could not find it in list
thanks
  • Zanussi Master
  • 909 Answers
Need to remove pump to open and check what is sticking in the impellar. Check pipes for blockages. Also check pump motor by itself. reassemble and retry.
Posted on Jun 06, 2010
Rinse or spin cycle not working
check the pump for blockages. it's at the front on the right hand side, just lean the machine backwards. it unscrews. make sure you unplug and empty as much water as possible first!
Sep 13, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool washer wtw5300 rinse water not emptying at all
pull pump see if it is blocked see if you can spin it
Feb 25, 2012 | Whirlpool Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My zanussi washing machine keeps stopping during the rinse cycle with a flashing "error code 20". I have even tried to bypass the rinse cycle and put it on to spin or drain but it will not work. Help?
Thanks for using FixYa - a 4 THUMBS rating and positive testimonial is appreciated for answering your FREE question
Oct 07, 2010 | Washing Machines
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
At the end of the rinse cycle, water and suds will
Does water empty on spin? if not to check for blockage remove waste pipe from drain, place as low as possible into bowl, if water flows then fault likely to be on pump, if no water flows then pipes blocked and need to be removed to clear them. Good luck
Feb 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Zanussi FLA1101W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
