Question about Maytag MFI2569VE Bottom Freezer French Door Refrigerator
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
    Scholar:
  • 44 Answers
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Posted on Jun 06, 2010
Every 15 seconds the refrigerator beeps and i noticed the refrig light was out. I replaced the bulb which is now working but it still beeps every 15 seconds. tThe temperature in both the frig and freezer...
I don't know if you have an ice maker but when my ice dispenser is full my fridge beeps because the ice can no longer go into the tray because it is full so I have to empty the tray. and the beep stops it also beeps when the water filter needs changing. I hope this helps
Feb 23, 2011 | Refrigerators
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Water in door will not work
I need to know the make and model # to more accurately help you. First and foremost, you will need to thaw your holding tank with a steamer...do NOT use heat gun or hair dryers. The problem could be one of several but I would start by checking the solenoid that supplies the dispenser to see if it is burned out. It is usually located in the back lower part of frig where the water inlet line hooks to. There are usually 2 solenoids.... the ice maker and the dispenser. Unplug the frig before testing these. The resistance across the ice maker and dispenser are usually the same. If the dispenser solenoid is "open" on the ohm meter then the whole water supply valve needs replaced. Another problem with some units where the dispenser is on the FREEZER side...the lines behind the door will freeze. I've seen this with LG's and GE's. They make a special heater modification for units notorious for this latter problem.
Nov 25, 2008 | Refrigerators
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MFI2569VE Bottom Freezer French Door Refrigerator Logo
242 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
