Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMF720P Error code H20. What does this mean? Wash light flashing at same time
5 Suggested Answers
SOURCE: HOTPOINT
either a blocked filter or tap not turned on
Posted on May 02, 2008
SOURCE: I've got a Hotpoint WF541.
Hiya. Same thing here. Did anyone find out what they mean and how to fix it? Cheers.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Posted on Jan 31, 2010
  • 3230 Answers
SOURCE: Error code H20...My washing machine, a hotpoint
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Posted on Mar 02, 2010
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Hotpoint Aquarious WF630 error code H20. It will fill and wash with both hot and cold water but when it gets to rinse and spin the error code flashes. It will however spin if i manually change the...
H20 does in fact indicate a problem with the incoming water supply.
Check the inlet hoses/s to make sure they are not kinked or restricted in anyway, more so when the washer is pushed back.#
Make sure tap/s are fully turned on, make sure you have good water pressure.
It would also be a good idea to check the gauze filters in the inlet to the valve/s.
Feb 08, 2010 | Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint
Here is the link to you washer. unfortunatly i can not find the error code you are seeing. you can contact them and have them let you know what the code means and what to do to fix it.
you will need to copy and paste this into your browser.
http://www.hotpoint.co.uk/macro/product.d2w/report?typeref=&prnbr=WD640
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Aug 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wont do a wash cycle
If the pre wash led is flashing it indicates a h20 error (time out filling) some common causes are fill hose twisted trapped or kinked tap not turnd on the waste hose is connected incorectly and is causing the applionce to syphone if your waste pipe gose into a down pipe ensure it is in no more than 4 inches maximum and if it is connected to the u bend undr the sink you need to make sure the pipe gose above 60cm high at some point.
Feb 19, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
281 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
