Question about Honda Garden
How to change drive belt on Honda HA4120H48A lawn tractor Where is the tension release? How to re-thread a new belt on the drive & tension pulleys?
SOURCE: drive belt loss
i had the same problem, i even took it to the dealer and they couldn't fix it. After a while I finally figured out that the belt tensioner was slightly bent down. I straightened it out and I haven't had a problem since. I hope this helps
Posted on Apr 03, 2009
Techjoel
  • 79 Answers
SOURCE: Diagram for Lawn tractor instalation belt
managemyhome.com has many manuals for yard machines/mtg lawn tractors.
The information you need may be generic and therefore almost any manual may help re-install the belt. This manual is for the 660-679 series. Once at the site you can check different model numbers for one that may be closer to the machine you have.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403122.pdf
Good luck,
Techjoel
Posted on Jun 05, 2009
  • 376 Answers
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Posted on Jun 28, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
mickey813
  • 472 Answers
SOURCE: Self propelled mower no longer propells
SOUND LIKE THE TRANS IS WORE OUT
Posted on Oct 01, 2009
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
Blade belt diagram for an is 2000 61 inch
I don't have a diagram but we just had to replace our belt and Here's how we did it. Note that the shiny gold/silver pulleys make contact with the flat side of the belt while the black pulleys make contact with the u-shaped side of the belt. If you look at the pulleys you will see they have different shapes to correspond with the different shape on each side of the belt. The drive pulley at the back makes contact with the u-shaped side of the belt.
Release the tension spring and thread the belt. Belt slips under the middle back pulley with the tension spring released. Then use a spring pulling tool (there is such a thing) or another method to pull the tension spring back over the bolt. Ensure belt is threaded properly with no twisting and nothing caught in the pulleys before firing it up.
Hope that helps.
Oct 27, 2012 | Ferris IS2000 61"" Zero Turn Lawn Mower...
Hi,was rolling my lawn with a yth2454 husqvarna.i released then pushed on drive pedal and it wont move.i replace the motion belt now it moves but barely.the old belt was stretched.also now there is a...
hay
it sounds like the new belt you fitted neads more tension on it find the tension pully again and get that belt a bit tighter make sure that you can get it tight enough not to slip!!!!
good luck
andrew
May 01, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you put the drive belt for the hydrostatic drive on?
You'll be working underneath the mower, so it is helpful to raise the mower chassis up -- at least in back. Use your automobile jack, then put jackstands underneath the chassis to do this. Take off the deck drive belt first by releasing the idler spring(s). Unbolt and remove the "anchor" that keeps the PTO clutch from rotating. Disconnect the electrical wires leading to the PTO. Release the tension on the idler for the hydrostatic drive belt. Now you can thread the new hydrostatic belt over the engine pulley and around both wheel motor pulleys. The idler pulley presses it inward to provide tension. Refasten the idler spring - a pair of channellock pliers works well to hold and pull the spring. Now reinstall the wires and the PTO anchor, then the mower deck belt. Good luck! Please rate my answer if helpful, thanks!
Jul 02, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Clutch does not work
yes, the clutch is only a mechanism for releasing the tension on the drive belt. Likely your belt is roasted.
Mar 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do i loosen the auto tensioner on my 02 civic si
2002 Honda Civic SI 2.0L MFI VTEC DOHC 4cyl
  1. Place a long-handled, boxed-end wrench or a belt tension release tool (A) on the drive belt auto-tensioner from above the engine. Slowly turn the wrench in the direction shown to release the tension, then remove the drive belt.
    WARNING This is a hydraulic type auto-tensioner; you must turn the wrench slowly.
  2. Install the new belt in the reverse order of removal.
Fig. Removing the serpentine belt-2006 Civic with 2.0L engine shown
Fig. Move the auto tensioner (A) to remove the serpentine belt (B)-S2000
Fig. Move the auto-tensioner (A) using the belt tension release tool to relieve tension from the drive belt (B), and remove the drive belt-Accord with 2.4L engine
Fig. Move the auto-tensioner (A) using the belt tension release tool to relieve tension from the drive belt (B), then remove the drive belt-Accord with 3.0L engine
I hope helps with this. Good luck.
Dec 29, 2009 | 2002 Honda Civic
Garden Logo
167 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
